Hi, I’d like to get Armourfend fitted to the nose and rear arches on an S2, any recommendations for installers in the Milton Keynes/south mids region?
Is Armoufend still the product most people go with?
Thanks
Thanks
Don’t know if it’s the same or different but I just bought another full kit of Ventureshield. Last one went on in 2010 and given the abuse it’s taken I think it’s done a pretty reasonable job. Much better than the factory stuff on the sills, which I think was Scotchguard.
Not cheap though.
thanks, I’ve just looked at Ventureshield, can you buy a pre cut kit then?
Yes - I got it through CN, there may be a more direct route but if you call Paul there he should be able to sort you out.
Personally I wouldn’t be confident fitting it myself, I’m getting it done through a local body shop.
Went for Ventureshield kit in the end, supplied and fitted by Jarrod at Bodyguard, Daventry, Northants, had the full kit done, really pleased with the result!
The best option is to simply not drive so close to the car infront.
It works for me all the time
^ ha, yeh I do that as well and never drive on gravel or grit the nose was not too bad on mine, sills and below the scoop get much more of a hammering!
Clearly you have superhuman levels of self control. Every trackday briefing says ‘no racing’ and we all nod dutifully. Then you’re out there, tootling along and you catch sight of another car either in front or behind. Is it someone you know ? Is it another Lotus ? If the answer to either is yes, then another rule goes straight out the window.
