Finally got round to fitting my new front brakes this week (and new track rod ends). Bells were supplied by JasonR in nice bling blue colour and rotors are AP5000’s. Really pleased with them - so much better than the standard lotus jobbies and I havnt even fitted new pads yet. Plan on fitting the same setup to the rear if Jason can arrange some more bells for me
Looks good, i take it the spacers worked ok ? Get you some more bells with pleasure, just make sure you can get a disc for the rear that doesn’t cost a fortune.
Spacers worked fine but ended up stripping the threads in the upright. The threads were poor as it was (top half of threads were damaged) and as the bolt length was shorter it wouldnt take the correct torque.
Ended up drilling out the threads and heli-coiled them. Threads are now better than ever. Got some slightly longer bolts as well.
Is it not possible to use spacers on the rear too and use the 295mm disks?
Jason are the bells still available for front and rear, missed the last lot.
Interested in getting some for when my current disks wear out.
Christian
In theory, with bigger rear discs, the rear pads will run cooler, and will take longer to get up to temp, which may not be a good idea for pads like RS14 that needs a bit of heat to work.
The eliseparts rotors are thinner than standard so i dont want to go down that route. The standard lotus jobbies are just plain pants and i’ve heard bad reports about the ebc disks. Basically im looking for an upgrade to the standard setup and IMO neither the eliseparts disks or the ebc are an upgrade.
Additionally, my standard rear disks look plain weedy when compared to the AP fronts I have and as Andy has just pointed out AP rotors = no rust ring!!
Im guessing the bells im using at the front wont work with these as they have 12 fixing points as opposed to the 8 you have on your bells.
145 quid all in each !
Yeah well actually I did think about using the same bell and a 4530 856/7 disc - but thought the 197 dimension was a bit close … but actaully I think you can get away with it …
