Live in Jersey, fed up with local dealer over charging and not knowing what they’re talking about or doing. Ferry comes into either Poole or Portsmouth so ideally looking for a specialist in the south.
Car is an S2 S and intention is to have it serviced this time but hopefully build up a rapport as I eventually want to upgrade the suspension and naturally that involves an alignment which I’d want done properly.
Hi and welcome. The main dealer in Poole (Westover) is quite good to be honest, i’ve never had any issues with them. I’ve also used Sportomotive in Salisbury who are a specialist and found them to be excellent too (they are a lot cheaper though, iirc �50 p/h labour charge)
Hope this helps
For a simple service- oil filter etc any lotus dealer will do tbh. - I do all that work myself it’s not hard!! What would cost you 300 notes at a dealer can be done for under a hundred quid and a couple of hours of your own time. Also if you do it yourself you can make sure the oil is well upto temp before you drop it, something a dealer would never do!!
If you want suspension fitted and setup then take a trip to see John Shorrocks at JSR racing. I have used John’s set up for the last few years… Won many races!! Ps go for Ohlins
Thanks Guys, usually do all the interim servicing myself, just like to get a stamp in the book once a year and I’ve got this problem that I cannot seem to fix myself. Will speak to JS racing.
From what i’ve read on here thinking Ohlins all the way.
