Got an oil pressure gauge for mine, but haven’t fitted it yet as it turns out there isnt enough clearance for the sender at the sandwich plate. It does seem a bit unlikely to me that there is any pressure problem caused by the twin cooler circuit - if you think how many Exiges must be thrashed at track days every weekend, and I have never once heard of anyone having a major failure with this engine. It really does seem pretty bombproof.
Well, as soon as I typed that, had a look on Seloc and it seems some people have had an oil starvation issue, although it does sound quite rare: SELOC Forums
Thanks Mark, you’re probably right. I just wanted to calculate how close they were to the limit and see if anything simple could be done to help matters (ported oil pump/sandwich plate, shimmed PRV etc)
Regarding your sensor - would it be possible to remove the engine oil pressure switch from the main gallery (assuming it has one) and fit a remote connection with a tee off for your sensor?
Probable a very good idea. Mates engine in a 111r just went bang on a right hand bend. 3 weeks ago filled car full with oil. Engine took 3 1/2 litres of oil to get it back to the mark. Lotus replacing engine under warrantee.
So check you oil levels
