Considering purchasing the air-horns from eliseparts.Obviously they must fit okay under the elise bonnet but wondered if there’s enough room under an Exige bonnet with the oil-cooler and air-con gubbins.So - anyone had fitted them to an Exige?Cheers, Tim
Not fitted them, but there is plenty of room on the front crash structure where the horns are fitted.
Thanks PhilMight take the job on then !Standard horn sounds a bit too weedy.Cheers, Tim
It’s a doddle… just remove the panel under the front clam. (Or you can do it via the wheelarch liner if you’re bendy) Bri
