Anchors
My brake pads need changing as they are quite worn down.
Had a search through past posts but can’t make my mind up which option to go for.
I have 4 pots with STD RS14’s, I had some fade and vibration at snetterton a few weeks back, is this because they are coming to the end of there life? I have been looking at the CL pads RC5 / RC6 as an alternative.
Interested to know your experiences with CL pads against pagids?
what fluid are you using?
Oh no, not again! Keep off the fluids!!! :smiley:
LOL…
hic!
i have the standard set up, new 2010 RGB, however what you describe is exactly what i had at donny. the lads thought it was the fluid.
Gravy?
Yup - Lotus stick std dot 4 in production cars - get some SRF in quick and stick with the RS14’s IMHO :wink:
i’m doing the same…thanks Chris
Vibration?
Do check the whole disc, inside and out for cracks, usually starting at the outermost drill holes
RS14’s!!! AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!
They are worse than not telling your wife you have bought a car 6 months ago!!!
So many better options. All in my opinion of course :wink:
RS14’s are great until you start to get the dreaded pad transfer then they become a nightmare.
Given them a go a few times. Same result each time.
Try the CL5+ or CL6’s.
I am on the CL5+'s now and will give the CL6’s a go next.
Ex77
When the current RS14 wear past halfway they shoud be thrown away IMO …
They changed something a few years back and they have never been the same since for me … different smell as well …
[quote=AndyD]When the current RS14 wear past halfway they shoud be thrown away IMO …
Smell ??? - is it cheese ? :smiley:
Second that, it makes me laugh when I see used ones for sale… :crazy:
[quote=SeanB]RS14’s!!! AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!
So many better options. All in my opinion of course :wink: [/quote]
Come on then Sean - better options ???
PF’s worn to the bone still worked a treat for me.
[quote=chrisexigegt]
Come on then Sean - better options ??? [/quote]
Swapped my RS14’s for CL RC5+, so far much better on the road and I’ll let you know how they go on track at anglesey but feeling from a little play on the road is good :slight_smile:
Thanks for the replys. I always thought RS14’s were a really good spec.
I have had a couple of late breaking moments on the last couple of trackdays with bad fade. Think I am going to have a go with the Quiche Lorraine RC6’s. Is it always best to change the pads all round?
[quote=marcp]
Second that, it makes me laugh when I see used ones for sale… :crazy: [/quote]
I’ve got my half worn std clutch plate for sale … any offers ??
:smiley:
