Am i ready?
^^^ and this kit doesn’t even use additional air intake …indicating clearly that there is headroom in a Forge /mmg/RLS intercooler for an even smaller pulley if you so wish …
Note dyno plot does not show AFR. Looks interesting though
Eh ??
What’s AFR got to do with intercoolers ??
:crazy:
And 30kg lighter than a C/C :slight_smile:
Because intake temps affect AFR ?
My comment was that the AFR readings were missing from the dyno plot which were on the dyno plots you posted back during the big AFR bunfight
http://www.exiges.com/ubbz/ubbthreads.php?ubb=showflat&Number=151648&page=10
Surely as per your dyno plots you need the full picture including AFR to make any accurate asessment
there is no way my CC kit weighs 30kg more than an IC maybe 10-15kg tops and most of that is water and the pipes from front to back
I was told this lot was 18kg in the box:
The kit consists of the following parts…
1 x Pro Alloy charge cooler
1 x Pro Alloy auxillary radiator
2 x SPAL motorsport cooling fans
2 x Air con re-mount brackets
1 x Alloy header tank
1 x Bosch Electronic water pump
9m Rubber water hose
All clips nuts/ bolts required
  • the water to fill the front rad + water in the pipes from the back to the front - twice + water in the header and cooler core .
[quote=ade]
there is no way my CC kit weighs 30kg more than an IC maybe 10-15kg tops and most of that is water and the pipes from front to back [/quote]
Forge is 5kgs in total, the CC unit must be at least that empty, plus the front rad, pump and all of the heavy rubber hoses… then there is the wather (as they say up ere).
But I would say 15kgs or so more is realistic working on a slightly heavy mountain bike being 15kg’s.
However, none are as light as a crab stick :smiley:
I love it :smiley: not constructive but crack on fellas :blush:
They do crab cakes light now ?
don’t forget the fans are replacements for the standard ones as well so you have to remove the weight of them.
Yep they are called ‘S1 Crab cakes’!
Yep they are called ‘S1 Crab cakes’! [/quote]
Past there sell by and I bet they fall to bits in the pan and most People change the filling because theres no real meat in them . :slight_smile:
I like crab cakes!!
As much as Naan?
nothing is as nice as a soggy bit of naan!!!
New term - NFR - Naan to Face Ratio !!! :smiley:
I have a very high NFR as looking at my waist line, im certainly not running lean!!!
That’s me back from EA with mixed results.
Had Wayne fit 440cc injectors as they still hadn’t got 550’s in and the pulleys hadn’t arrived either.
Car ECU was unlocked and mapped giving me 243bhp @ wheels with 164lb/ft. Car feel sharper on throttle but now randomly cuts out when stopping… and the engine management light has also now come on.
Called EA twice this morning and Wayne was asked to call me back. Fingers crossed he does before it gets worse.
