I am looking for one, but no luck.
Where can i buy one from?
I’ve just tested the original plastic rail up to 10 bar pressure and it is ok (i.e. no leaks or anything). So, no alloy rail is required any more!
Thanks anyway for your help.
At room temperature George ?
I am afraid yes Andy. I only turned on the fuel pump and increased the pressure as much as possible. Do you think it might have any leaks/cracks when hot? I am only going to run it at about 3.5 bar pressure thou.
Ideally i could use an alloy rail, but i still don’t know where to find one!
