which is the better pads for 308 alcon for have low noise ,
i have RC6 and it’s to much noise
an idea i think test RC5+ ,
what do you think
I’ve used the RC 5+ onalcons and thought they were really good. Not as good as PF but with none of the wheel eating dust. I don’t recall noise with them
Hi , which REF with the PF
I’ll look when I get home. Did I say I was in Meck- kicko?
JDS will probably remember. I think it was the only compound they do that is available for both the 2 pot And the 4 pot,??? '99
JDS is your man, I think I run compund 01 front and rear I think
Things have moved on a little
4pot fronts 01
2Pot fronts now 11 (newer version of 01)
Rears (Brembo) 08
Lotus 4 pot motorsport is 01 your 2 pot rears are 11
Nice to know LOL They work well which is all I care about
No Noice with PFC 2 pots fronts 11
less or more better than RC5+
regards
hello i have buy PFC 2pots for alcon 308 and it’s infernal the noise
i have try RC6 carbon lorraine NOICE,it’s with pagid rs 14 that i have less the Noise ,
a problem with the disc impossible to drive like this …
SOLUTION ??
What is the noise that you have?
If the PF pads are squealing in use, get them hot and keep them hot. Of all the sets I have supplied, properly fitted only one set has squealed.
All the pads you have listed above are a race spec pad, and don’t like road use.
the pads are squealing more and more when they are more and more hot ???
3/4 braking cold no problem , but after
the discs are new 500km and one trackday and the pads received today ,all buy to serioulylotus
all the pads ok…but use before girodics of sector111 with pads rc6 and no problem
Problem of couple of tightening, of qualitée of screw (8.8 try 12.9) or holds???
Not quite sure what you’re saying in the last bit.
If you have only got the pads today, have you done a track day already? You won’t get them hot enough, for long enough on the road, plus you need to clean off the pad deposit from the previous non PF set of pads, which can be a challenge with some of the pad materials out there. Give it some time, do a track day, don’t use race pads on the road over winter.
I have to pass disc and pads has the painting(cloth, In the papiere of glass), I live has the mountain, it is not a problem to warm pads
Hello ,the AP 295 disc is the same bold taht the 308 alcon (177.8) ?you use spacer to use with the 2 pots front
i have buy to you alcon 308 and test all the pad (PFC,RC6,and RS14) the same problem noise noise noise,hot or cold)it’s not adapted for the 2pods fronts i wait to your information for buy ap dics
regards Franck
For my problem I have to contact directly alcon ,Max Fortis and he speak french…
They have to contact seroiusly lotus and I have return the disks as Dave has him to me to ask, he received them via ups yesterday…waiting…
