I plugged in the Accumate last night then tried to lock the car to silence! The key fob wouldn’t work so the immobiliser kicks in and I have a car that I can’t lock or start!! Tried the spare key with the same effect.
After much ranting my calmer wife suggested we try to re-sync the keys. This didn’t work and added to my less than happy demeanour. Luckily being a Dr. my wife ignores the swearing and takes me thorugh the programming of the fobs using the pin. Success!!
I’ve not had this before and wondered if I suggest expect to go through the same every time I plug in the charger?
Lost count the amount of time i have used my accumate on the exige, never had any issues, although i cannot remember ever arming the alarm while it has been on charge
(much calmer now)
Youve either disconnected the battery to connect your Accumate jack plug or let the battery discharge too low: I’ve just been through the same thing over the weekend and ended up replacing the battery as I’ve let it discharge too low between charges and fried the bloody thing.
I had a feeling that connecting the Accumate up (via plumbed in connectors) triggered a reset. I hadn’t used the car for about 10 days, but don’t think the battery is duff as all the lights etc worked without the accumate on. I wonder if the Alarm ECU is sensitive to sudden increases in power?
