Can anyone tell me what the actual airflow should be set at through throttles? In the manual it says 8kg/h but most of you seem to be setting it at 5kg/h. I have the lotus 190 ecu if that makes any differance.
Very very sorry. Can’t help with the problem but would like to know where you got the manual. Or has anyone put the thing on the net. Sorry again.
the manual came from Bell & Colvill, mainly covers elise with sections for 340r & Exige about �47. Any main dealer should be able to get you one though.
Yep they certainly have. Do a search on here, Theres a link to it on here somewhere.
Or someone will pop along in a minute and probably do a link straight to it
Jay, click on Phil’s name, go to his website and download.
5kg/h or 8kg/h?
IF I remember correct … 5 is applicable to an Emerald ECU being fitted and 8 a Lotus ECU … search for Mike Lanes throttle sticky problem
Thanks for that, every time i set and balance at 8kg/h it wont idle below 2000rpm. Could it be the IACV valve gap not set correctly? any idea what it should be.
