Accusump purchase...eBay?
Anyone ever bought one of these from eBay? If so which one did you go for and what other ancillaries are required as the kits listed seem limited in parts.
Any pointers much appreciated.
Forgot to add that I’m looking at listings from the US as there don’t appear to be any uk suppliers on there.
I got mine from the US via eBay, JSR fitted it and I got all the required connectors and hoses from Think automotive on John’s recommendation :wink: Total was about half the cost of the kit from Lotus plus mine is a 6 pint rather than 4 pint Lotus use :wink:
Size is everything Ade !!! :smiley:
Mines a YARD! :blush:
Mines a YARD! :blush: [/quote]
What ? Your’s has sheep, chickens, kangaroo’s etc ??? :smiley:
More weight ???
Yeah I noticed that it’s about 50% cheaper…which is everything this time of year esp after forking out for a new set of tyres.
Ok so let me get this right…is a 6 pint equivilant to 3 quarts??? After seeing the umpteen different auctions for differing specs I’m totally lost (!)
Ade theres a decent bottle of chateauneuf du pape with your name on it for a steer here. Would this kit do? Ebay CLICKY
Yep, that is what I bought, drop them a quick line and ask if they will put $100 on the import form, it will save you on the import duties :wink:
it seems to have all of the relevant valves etc that you need, but as I said before you will need the correct pipe T pieces filters etc from Think about another �120 or so, then fitting etc.
Cheers matey. Very nice of you…PM me your home addy so I can send france’s finest grape juice your way.
Did JSR source the T pipe, etc for you from Think Auto or did you wait and see what turned up and add the bits yourself?
As the Accusump kit only comes with what is in the picture and everything else that is required is extra, you will need to get it from Think, speak to John at JSR if you have any worries, but Think do know exactly what you will need to fit an Accussump kit into the Exige it is only the length of hose that can change dependent on how it is installed (just about every install I have seen is different).
Cheers Ade, spoke to Think and I’ve ordered all the additional parts now (�174). Just out of interest is your Accusump kit the 40 psi or 55 psi one? Lotus apparently used to fit the 40 psi one but now fit the 55 psi unit…
I think mine has the 38psi actuator, this is only the pressure switch which is the point it either
A Adds oil
B Tops itself up
There’s a new one for sale on Seloc… member Taz
Here’s a link…SELOC Classifieds
