[image]SELOC | Lotus Enthusiasts Club
Just back from an excellent weekend at Le Mans with Club Lotus France. 2 days on the Bugatti circuit, staying with friends and a lot of sunshine.
However I count myself pretty lucky to be here to tell the tale…
2 laps into my fourth session on track in a fast sweeping right hander after the Dunlop bridge I suddenly had a bad vibration from the left rear wheel.
I slowed and trickled back to the pits my immediate feeling was perhaps a puncture.
In the pits its obviously not a puncture, no sign of a big lump of rubber picked up on track, there is no movement top to bottom when trying to rock the wheel but there is lateral movement… toe link?
A French Lotus dealer was at the track giving support and he seemed to agree, puts the trolley jack under the car, two or three pumps… and the [censored] wheel nearly fell off! All 4 studs were barely finger tight and only a couple of turns left on each!
Before leaving home the car had been in for a service and oil change, I had changed the wheels and torqued the nuts up.
On the way to the ferry I had called at “a leading Lotus motorsport specialist” to have a sender unit for the oil temperature gauge replaced. They had agreed to fit in the visit en route from Cornwall to the Le Mans Track Weekend… which they knew.
They removed the rear wheels to adjust the weight balance and to avoid the car tipping off the 4 arm lift. The sender and sump plug were replaced, I paid the bill and set off for France…
Now it is just a coincidence that the last time they did a geo on my previous car they set one rear wheel toe in and the other toe out… that was interesting too!
Now all you seasoned track go’ers probably do this already but those of us who only go on track 3 or 4 times a year rely on so called specialists.
So… the lesson… DON’T TRUST EVEN THE EXPERTS, CHECK THINGS YOURSELF
I have not “named and shamed” as I haven’t had chance to speak to them yet, it happened late on Saturday and I only returned home at 5am Monday morning. In my book there is no excuse for negligence like this… I feel that I used up a lot of my luck in France this weekend.
