A few of my latest modifications
I’ve got a big list of things I still want to do to my car, but these are tasks I’ve managed to finish recently, so I thought I’d post a few piccies.
Firstly, making a proper front splitter to even things up with the motorpsort rear wing. I would have just bolted on one of those ready-made plastic ones, however they’re a bit flappy at high speeds. I’ve made this with 10mm marine ply which I hope will prove strong enough. It goes right back past the wishbone line and is secured with about 15 bolts very securely. A friend made the fairly basic front bracket/bolt for the supports, which bolts through the steel tube above the tow eye. It’s tough and I (85kg’s) can stand on the front of it.
Another little project was to try and give the air filter some additional fresh air. So I have used a dremmel to enlarge the roof scoop and then made a new mesh grill for it. It’s now about twice the size. Then, a friend has made a perculiar looking ally contraption which fixes to the original engine cover hinge bolts. It leads to three tubes that I have used to channel air to the filter and charger.
Lastly was just a small job which I thought was worth doing as the car is now producing 330bhp at the hubs. This was to remove the standard air filter flexible tubing and to replace it with some ally pipe and samco hose. This is much smoother internally and doesn’t deform or get as hot. Hopefully, the engine is now breathing to its preferred level.
Most importantly, I’ve got real enjoyment out of doing all this stuff myself. Right, I’ll stop boring you all to death now.
[image]imagecave.com - contact with domain owner | Epik.com 001.jpg[/image]
[image]imagecave.com - contact with domain owner | Epik.com 003.jpg[/image]
[image]imagecave.com - contact with domain owner | Epik.com 002.jpg[/image]
[image]imagecave.com - contact with domain owner | Epik.com 004.jpg.jpg[/image]
[image]imagecave.com - contact with domain owner | Epik.com 005.jpg[/image]
nice ideas. Any pics of the underside?
Got a wishbone fetish, Steve?
Cool! Nothing like a good bit of DIY!!
Yep, nice work Jamie
Fingers crossed you don’t hit anything with the front splitter, cos it could prove expensive…but you know that anyway!
Mate - I’m in urgent discussions with my Integrity Manager at work to see if I can get mine x-rayed, ultrasound tested or some other high tech method before I know it is safe to take out of the garage again
Can’t really get a decent underside shot but here are a few. Did Brands yesterday and it showed no signs of coming off, even with a 100mph excursion onto the bumpy grass. I did graze it going into a petrol station on the way home though.
I found the easiest way to knock your splitter off was to park facing a kerb and then try and start the damn thing in gear … Crack … Damn
Crack … Damn
You want to lay of that stuff, mate…
Hi, have you put those bolts go through into the crash structure or into the clam?
Will
Looks like the front ones are into the original Splitter floor and the rear ones are just where the original splitter bolts go to the chassis …
Yep, that’s basically what I’ve done.
However, that sheet of ally with the holes in, which is normally used to allow hot air out from the original oil cooler and which the original splitter mounts to. Well I’ve turned that the other way up and firmly attached it to the crash structure with threaded bar. This gives my new splitter something rock solid to attach to.
Jamie
Expect a visit from “The Wishbone Boyz”
W96 TPW was Silver … right ?
Indeed. A few people including Carsten, Anthony R etc have previously owned it. It’s a ‘Prototype’, which I have completely bastardised.
Cool man!!!
