When I start my car from cold, it revs straight to 3000 ish RPM for a second or so before settling down to 1100 ish.
NOT good for my mechanical sympathy for a cold engine! Especially as the winter draws in… Does anyone else suffer from this? is there a fix? or is it a TADTS!
I’m curious, why would an acusump cure it? [/quote]
When you turn on the ignition, the accusump ‘primes’ the engine by dumping its oil in there therefore effectively pre-lubricating the engine before you press the start button.
When you turn on the ignition, the accusump ‘primes’ the engine by dumping its oil in there therefore effectively pre-lubricating the engine before you press the start button. [/quote]
Comes as standard on the Cup, well its on our’s and if I could drive half as quick as some of those on here (yes you know who) I would want more horse’s
Pete Not sure there is much difference HP wise in the end between either the Gotham or CN one, plus you can still add the bigger pump to the Gotham it makes no difference to the map
You pays your money and all that
