Hi Guys,
New here i know. Just bringing over a couple of adverts i have on Seloc currently.
Thanks,
Have a ‘Revised’ Model 4-1 2bular Manifold and decat, wrapped in the very expensive DEI thermotec wrap with metal ties. Nice and neat installation.
Comes with Manifold gasket, not included O2 sensor as pictured.
This is the revised 4-1, suitable for supercharged Elise and Exige varients.
Used for literally 800miles, most of which was dyno testing, car was taken in a different direction, hence this lovely engineered header is surplus to requirements.
All ready to go, wanting £550posted. Please U2U with email and ill send pics direct.
Also have a BOE Fabricatrion Baffled Sump to fit the 2zz Toyota engine found in the 111R and Exige.
Very similar to the Moroso Sump, however it holds extra capicaity for cooling, has more baffled areas, and also comes with a crank windage tray to stop the oil whipping in the sump at high rpm. Also has provision for oil temp sender and turbo drain pipework.
Great product, only removed to fit dry sump, circa <1000miles. Was used on a track car with Zero issues. Lovely engineered piece with great welds and quaility fasteners. Comes complete with studs and nuts to fit.
Pictures to follow. U2U for my number/email. Will post at cost.
Thanks again,
