What are the Best Vacuum Cleaners for Hardwood Floors?
Are you wondering what the best vacuum cleaner is for hardwood floors? A vacuum may scratch the wood surface when it picks up dirt and debris. Rubber wheels could be made in place of plastic ones to protect the floor and accessories would be better if they contained soft bristles or pads of microfiber. A vacuum that has a beater bar should be able to turn off the spinning bar to protect the surface.
Related Article: What is the best vacuum cleaner - Top rated vacuum cleaner reviews
Many vacuums are available for wooden floors, from uprights to canisters and some are cordless. Make sure to consider whether you want a vacuum only for bare floors or if you prefer a flexible vacuum for carpeting as well when you start shopping for the right vacuum. Below are two recommendations based on best vacuum cleaner reviews.
1. Shark Rocket Ultra-Light Hand Vacuum HV320
The Ultra-Light HV320 Shark Rocket Vacuum is a lightweight vacuum cleaner. Its original body style helps it to bend and get into tight spots and even under low surface furniture. You can transform it into a handheld vacuum easily. The variable speed control of the roller helps users slow down the brush movement while cleaning hardwood floors. You can also easily pick it up to handle upholstered surfaces easier. You can transition to a rug or carpet with a toggle button. When in operation, there is a bright LED headlight which illuminates the trajectory of both the vacuum head and the handheld unit while in operation.
The possibility of turning the Ultra-Light Shark Rocket into a handheld vacuum adds value to this compact floor-cleaning machine.
Selected For You: Which is the best vacuum cleaner for home: Reviews and Buying Guide
2. Shark Navigator Lift-Away Upright Vacuum NV352
This is one of the best rated vacuums for hardwood floors. The NV352 has a brush roll that is easy to turn off to ensure that laminate and hardwood floors are not scratched. The user can unlock the body of the vacuum by pressing one button. The stairs and furniture can quickly be swept. Also included are a wide brush to remove pet hair from fabric, a narrow flap and a broad flap tool.
The Shark Navigator has a pivoting steering system for sharp turns with its upright configuration. Furthermore, it can reach beneath cabinets and sofas with a low-profile front.
What should be expected of the NV352 Navigator Shark?
Due to the lifting-function which enables users to remove the canister from the hardwood floor, this upright vacuum can double as a canister vac. It can be used in other places which makes this a great option for customers.
The older Shark NV501 does not have the caddy feature. But when you want to clean stairs it’s still a good tool. It can also be difficult to balance as you know from when you’ve tried vacuuming stairs with a full-size vacuum. Additionally, the Lift-Away Navigator has a 25-foot power cord, a washable HEPA filter, and a safe haulage system. It deserves to be on the list of Best Vacuum Cleaners Reviews.
We hope you found our post helpful with the two recommendations above. Thanks for reading, and we’ll see you in our future posts.
