I have 295’s on my 10" x 18" rims, but really you could do with 10.5’s or 11’s. There is only the slightest stretch though and that is with a R888. I like it because it makes a nice rim protector as I am deadly when it comes to kerbs.
My fronts are 255’s on 9" rims and those are a perfect fit.
Shaun, that clam looks badass. I reckon in the new flat wide bits either side at the back, you should cut some vents in, like at the back of the front wheel arch. Would look awesome
Have you cut away the inside of the front wheelarch obove the sill so you can get to full lock without scrubbing? I assume they are the 888’s that work out 638mm diameter overall. Bet you can’t get the ride height that low with those bad boys on can you? I use that size on the back of mine!!!
Those 255 will wear right through the headlight bucket on an S2 at stock road settings, what are ya gonna do when the car is set up for performance…Instant oversteer and rubbin…
My 215/40/16’s will buzz the headlight buckets with a passenger and I run 550 lb springs up front with a 115cm ride height… :whistle:
