220 to 240bhp.... whats required
Contemplating upping from 220 to 240bhp over winter.
Is it just an ECU flash and injector swap?
Fuel pump?
220 clutch take 240bhp?
Rough costing?
What model year is your car. I have a 240 ecu for sale if you are interested.
2007
I think you only need the fuel pump and injectors if your going to 260
Won’t be going 260, just 240.
If injectors and pump for 240, won’t the ECU need swapping to?
Think it’s just ecu and injectors for the 240 fish, the bigger fuel pump is for the 260 i think.
May be wrong
For the 240 I think you can just do ecu
For the 260 you need injectors and pump and ecu
to go to 240 will need injectors as the 220 only has 330cc and the 240 came with 440cc which it why it is cheaper to upgrade a 240 to 260 :slight_smile:
May just as well go for the 260 straight away unless someone has a complete 2nd hand setup cheap.
I need to cost it up for ECU and injectors… then work out if its worth the extra 20ish BHP any gains in torque and will it be noticeably different.
When I had the 260 kit fitted to my 220 about 5 years ago it was about £2k which was done by Chris Neils and included a service.
This included a new 2/11 ECU (which was sent back to Lotus to be mapped), Injectors, fuel pump & TRD intake. The invoice went with the car so cant give you a breakdown, but now you can get a reflash to your ecu which should save about £700/£800 I guess.
Oh and just do it you wont regret how the car goes with 260.
That is not enough to go to 260… the Cup260s also have a light weight flywheel, light weight intercooler duct and a larger intercooler. The ducts have a larger ID and smoother walls for better flow to the larger intercooler. The Cup255s and the Cup260s have a unique intercooler also. So, if they told you you got upgraded to 260, you got ripped off if it didn’t include the flywheel, intercooler and intecooler ducting.
Those parts are not need for the car to make 260bhp Nice to have but not an absolute must.
Exactly, what a load of old tosh :crazy:
I went from 240PP to 260, with the upgrade carried out at Lotus Sport in Hethel no less.
Essential items for 240-260 is ECU and fuel pump (+‘cap’). From 220 add the larger injectors.
I was quoted for the flywheel but didn’t go for it. I did add an accusump though, but agin it was not essential for the power upgrade.
It is a fab upgrade the 260 :smiley:
got to agree with Dave, Flywheel does not give you more HP, the improved intercooler will only give you the HP for longer till it heat soaks, and the intercooler pipes are just lighter.
The biggest worry you will have will be the longevity of the standard clutch in a 220hp car, expect to change it soon and have that costed in your mind and you will be fine :slight_smile:
All the other stuff can be added later to improve the car :wink:
Think you said it… “that’s not enough to go 260, the cup 260s have”
The bits alone make it a 260. The other bits are just a improvement on the cup cars.
I had mine done in March this year and have a new flywheel and Clutch to buy this winter off Dave.
Exactly why 240 is where I want to go, the 220 clutch should take 240.
This time next year, I might go to 260 but for now I’m spending cash on a few cosmetics, tyres, braided hoses etc…
Also just for clarity the Cup 260 doesn’t have a bigger intercooler or lighter shroud. The only difference is the lighter tubes. The Cup 255 however does have a larger intercooler.
It was first introduced on the 255 and is also on the 260…
Don’t fanny around … just 320 it !
I beg to differ, i had a Cup260 and the intercooler was normal size, for whatever reason they reverted back after the Cup255. The only difference from a 220 or 240 car was the lightweight tubes. :smiley:
