211 Ecu in a Exige
Hello
does the 211 Ecu (260) for white dash work in the Exige with white dash and 440injectors?
What is with the immobilser, traction control?
Has any one experience with that?
Sounds like the boothy 260 mod which means it will work but you need the higher rated fuel pump. Please see thread below
http://www.exiges.com/ubbz/ubbz/ubbthreads.php?ubb=showflat&Number=126697&page=1
I bought new 2/11 ecu which was then flashed by lotus and gave 266.7hp. Need uprated fuel pump.
Yes it does :slight_smile:
I ask because i can reflash my old Ecu to 260hp or for same money i can buy an new 211 (260) Ecu.
AFAIK Lotus cannot/will not reflash the white dash ecu to 260, this came dirct from lotus. This is also the reason we have to buy 211 ecus.
Boothy
But the 211 ecu will work without modification or must it to be reflashed to work in a Exige?
Nope it will plug straight in :slight_smile:
Thanks Boothy
No problem! enjoy :slight_smile:
