Right… Not sure I ever saw myself doing this but after over 2 fantastic years with my exige S2 its time for a change.
I bought this car in early 2014 for my wedding car. Having always wanted a Blue exige I looked everywhere to try and find a good honest example. I found this car advertised on a lotus forum by a member who had owned the car from nearly new. The car was originally bought new from Stratstone Lotus Leicester in 2006. From 2008 to 2014 the car was then looked after by Brooke Kensington whereby it is well known and regarded ( I called them prior to me visiting the car to get there opinion ).
I bought the car as a completely standard 220s with roughly 19k miles on the clock.
Below is a current spec of the car as it stands now.
Sportpack from build including harness bar,T45 rollover hoop, Probax carbon effect seats, traction control, twin oil coolers (recently replaced).
Lotus 260 upgrade (Silverstone) including, Factory mapped ECU, fuel pump and bigger injectors.
Pro alloy Single pass twin core aluminium Radiator.
Pro alloy top mount fan Kit on laser cut mounting.
Stainless steel tow post with tow hook.
New rear discs
Hel Braided brake hoses
Belled 288mm Drilled front discs
Ferrodo Ds2500 pads.
Blasted & Re coated rear diffuser with new silver edging strip & stainless steel fixings.
TRD air box.
Black lotus badges (Nose & steering wheel and wheel center caps)
Large scoop mohawk roof panel. (Lotus upgrade)
Touring pack under seat and bulkhead carpets added
Powerflex yellow engine mount inserts.
Lotus 260 decals in Graphite.
Black wheel bolts
New Bosch S4 Battery
New Toe Links
New Drop links
Sony iPOD Stereo
Coated Wishbones
New spark plugs
Those who know will know that the car has had some nice modifications making it a lovely spec car. Oil lines recall was completed with 2 new oil coolers fitted by lotus Silverstone.
It really turns heads wherever it goes and the laser blue paint ( later colour ) is incredible when the sun shines on it. The car does have the normal stone chips that these cars suffer.
The car is really well known within certain circles of the lotus community so the car can be vouched for. Always kept in A1 condition and never left wanting for anything.
The car hasn’t been tracked and seems to spend more time sitting in the garage these days.
I am in the process of removing the private number plate but nowadays the dvla turnaround is days not weeks.
I’ve probably missed loads so please call to find out more. Its just a really honest low mileage car that’s never seen rain and lived in a heated garage. I have every bit of paperwork and invoice that I’ve bought and all mot certificates.
Service history
2006 - 932 miles - Stratstone Lotus.
2007 - 3679 miles Stratstone Lotus
2008 - 9334 miles - Brooke Kensington
2009 - Brooke Kensington ( will check service paperwork for mileage )
2011 - 13836 miles - Brooke Kensington
2012 - 14698 miles - Brooke Kensington
2013 - 17865 miles - Broke Kensington
2015 - 21228 miles - Unit 4 Burton
2016 - 22252 miles Unit 4 Burton
Mot until Oct 2016
£26,000
Kieran
