2 way Ohlins set up for daily driving??
Anyone with these care to pass on their settings? I don’t need track specific settings just peeps fav all round settings for compression and rebound.
Thanks in advance.
I can’t give you a full answer here, but I put mine to the (Lotus Sport) recommended track setting & run that on the road without issues. It’s not a daily driver though.
^^^ same as above ^^^
I found they tended to understeer a touch on factory settings and backed the front off 2 clicks. Far more settled.
Ok, dialled in the settings as recommended on the paperwork that came with the shox and it’s way too hard for the local roads near me. I noticed that when Trackclub fitted them they had set them a lot softer than Lotus Sports recommendations so will probably go back to something inbetween the lotus recommendations and the original TrackClub settings. I will also try softening up the front a tad to see if it helps reduce the understeer which i too noticed.
