2 way Ohlins purchased :)
So what Geo settings / ride height do I go for?? :slight_smile:
Cup settings?
I don’t use the car on the road that much if that helps.
And I don’t want it much lower than it is I don’t think.
What did you go for, Jonny?
LF Toe .25mm out, camber -0.5deg, castor 1.9 RH 128
RF Toe .25mm out, camber -0.6deg, castor 1.9 RH 129
LR Toe +2.5mm, camber -1.7deg RH 133
RR Toe +2.5mm, camber -1.9deg RH 130
Just wrote on Tony’s thread, feels great on track fecking mega infact and roads not too bad either. My only issue is setting the Ride Height to something more consistant to read but I’m worried I’d bugger the whole thing up!
I loaded the car recently with 2 up front and half a tank. I’ve forgotten the exact measurement but there was a 10mm difference front to back.
Oh and also my front wont go down any lower on these dampers regardless so I guess thats that!
