You lost me a bit there…i was joking about the S cooler intake, also i was not claiming that the reduction in chamber size incres�sed flow, i was saying it speeded up the flow.
Thats why the cross section of the intake and exhaust of a F1 side pod are significantly smaller than the cross section of the cooler itself. You allow the volume of air you need in, slow it down, pass it through the rad, speed it back up and exhaust it.
In some cases the exiting air can actually travel faster than the incoming air which would result in thrust from the cooling system. But this does not happen often…or at all in real life cooling systems.
Yeah, you’re right. I missed that
About the reduction in chamber size:
I’m still not sure I agree. Speaking physics, what goes in comes out one way or the other. Reducing the air towards the end of a tunnel or channel increases drag - the “speeded up” air-flow you are refering too, wouldn’t make up for the added drag it’s causing in the first place. I’m not even sure it would make any difference at all, except for causing even more drag. And if you’re causing more drag… then why do it in the first place?
It’s a bit akin to doing an experiment using a funnel and water. The funnel will act as drag in this case, which is why the water leaving it is less than the water you are filling in at the top. If it’s simply a tunnel that the water travels through, there wouldn’t be drag.
In the case of a F1 car - as I understand it - the large air-intakes work because it is sucked in by the engine, which burn it. It’s not air coming in and air coming out at the back. Given that it’s ignited together with fuel, the pressures before and after the combustion engine is different which means that the sizes obviously differ as well…
Since we are using this in an example to improve air-flow through an intercooler which is nothing but air passing through an intercooler (drag), I’m not sure how such an airflow could be benefited by adding even more drag by reducing the size of the tunnel towards the end. More drag = less air that can go through the intercooler.
Or am I missing something completely here?
