Im concidering selling my engine and gearbox setup, i thought id see if there was any intrest first. Heres a rough spec:
ENGINE:
Elise 111S 143 VVC engine (56k) running Emerald K3 ECU (Mapped by dave Walker himself)
2001 Lotus Exige throttle bodies/ airbox
ITG trumpet filter
340R exhaust manifold heatwrapped
Piper cams exhaust camshaft
DVA power 8degree offset dowels
Alpha 4.3bar fuel pressure regulator
2x bosch motorsport 5/6 bar fuel pumps (swirl pot fitted)
oil catch tank
Landrover remote thermostat kit
Mocal 24 row oil cooler kit
TRANSMISSION:
PG1 C4BP (rover C4BS) gearbox rebuilt with steel caged diff bearings and torsen limited slip diff (LSD)
PTP ultralightweight flywheel
AP Racing clutch kit
This will come as a complete unit with everything above including Emerald K3 ecu, software, manual etc. The ECU is fully mapped to the engine by Dave Walker. You will also get wiring loom for VVC/ Emerald all still fitted, remote thermostat, catch tank etc etc…
Will sell engine/box without ECU if you have your own Emerald and ill supply you with the map for the engine.
The engine is still fitted to the car and fully operational, you can even try before you buy!
Im not sure what its worth but i reckon �3000 is a great price as it has cost alot more than that and ive seen similar go for more. Heres 1 or 2 pictures of them before fitment etc:
[image]http://i55.photobucket.com/albums/g122/Gaz-M/Lotus%20Metro%20VVC/LotusMetro056.jpg[/image]
[image]http://i55.photobucket.com/albums/g122/Gaz-M/Lotus%20Metro%20VVC/LotusMetro066.jpg[/image]
[image]http://i55.photobucket.com/albums/g122/Gaz-M/Lotus%20Metro%20VVC/009.jpg[/image]
