I have available the (non-intercooled) S/C kit that is found on the later Toyota based Elises.
Its currently bolted on a engine sitting in my workshop, pretty much the full kit inc- supercharger, engine brackets, belt, engine wiring loom (later electronic throttle type)
Only things you will require to complete the kit is 4 new injectors which were not with the engine when I aquired it. You will also require a few tit bits such as new studs and a gasket for the inlet manilfold.
Price includes sending your ecu back to lotus for the relevant reflash.
The kit is suitable for either Toyota 111r or S2 exige N/A with electronic throttle. it may be able to work with manual throttle I dont know, I would have to check with Lotus on that one.
Please contact me for full details, as mentioned it is currently still on the engine in my workshop fully assembled. The prospective buyer may wish to collect in person and help me remove it from the engine if they are attemping to refit themselves to see how it all goes together rather than just getting a box full of bits.
