Anybody have a spare 190 ECU?
C8LGY
Cheers Rich, I’ve actually bought a second hand 190 to test, so should be able to sort it somehow. Wonder if it will run ok with the advanced inlet timing? Probably!
Yep, will be checking it’s a 190 with the OBD, luckily it looks like a kid has been let loose with a felt tip pen, so decent chance of it being real! 😄
hda
Evoman wrote: Wed Jun 08, 2022 11:37 am Craig,
I have a spare 177 ECU if that helps?
R
Hi -my ECU may be faulty as I am at loss with an unknown limp mode. Any chance I could borrow yours?
S1 #261
C8LGY
For info, Lotus can’t supply them anymore, and the 3rd party they were using for repair have went into administration due to covid. However, Espirit Engineering can potentially check/fix them, and I believe they may have an Exige ecu in stock too. [email protected] if you’re interested.
hda
C8LGY wrote: Fri Jun 17, 2022 7:09 pm For info, Lotus can’t supply them anymore, and the 3rd party they were using for repair have went into administration due to covid. However, Espirit Engineering can potentially check/fix them, and I believe they may have an Exige ecu in stock too. [email protected] if you’re interested.
Thanks, I’ll give it a try
S1 #261
Evoman
hda wrote: Wed Jun 15, 2022 7:36 pm
R
Just back on the forum so only seeing this message now - PM me and we can try and sort something out.
hda
Thanks I think I may have found an Emerald!
S1 #261
C8LGY
hda wrote: Mon Jun 27, 2022 1:53 pm Thanks I think I may have found an Emerald!
Remember to reverse the fuel relay wiring!!
Create an account
Register
Sign in
