When warm, idle drops and stalls
rossi_p
Hi all,
Randomly on the last drive, when engine was warm, when I dip the clutch the revs drop so low it stalls.
Ended up having to re-start every time pulling up to traffic lights. Also tested just dipping whilst driving along and stalls as well (but obviously can re-start lifting clutch agin).
Any ideas? Completely random and wasn’t doing it before….
Unmodified 180bhp 25k VHPD.
Thanks in advance.
series_one
Blocked IACV.
rossi_p
series_one wrote: Sat Apr 23, 2022 6:29 pm Blocked IACV.
Thank you.
For the mechanically inept, what does this require?
gonein60seconds
Hopefully this helps 👍
S1 #501
rossi_p
Thanks very much
thommo
Used to happen to me then, suddenly, it didn't. Hope you cure it.
Exige S1 No: 139
rossi_p
thommo wrote: Sun Apr 24, 2022 8:28 am Used to happen to me then, suddenly, it didn't. Hope you cure it.
As in you didn’t do anything to fix?
tlracer
Make sure there are no splits in the vacuum hoses or the T-piece connectors.
C8LGY
If the above suggestions don't work, it might be worth setting up the idle speed so that the IACV is almost closed at warm idle. Just wait until it's warm, keep adjusting the idle screw until the speed increases (nothing will happen initially, as the IACV will close as the throttles open), and then back it off slightly once the revs rise.
thommo
rossi_p wrote: Sun Apr 24, 2022 8:52 am
Well, nothing specific was tried , so could not be sure what, if anything, cured it. Maybe just regular use
Exige S1 No: 139
Create an account
Register
Sign in
