Helmets.
for any non Lotus car talk or projects.
andybond
Site Admin
Contact:
Happy Christmas all!
How can you determine what is a decent helmet and what isnt?
I spy 4000 different brands. Some I recognise like Aria or Bell. Others I dont.
I would hate to discount something because I hadnt heard of it and it was the best ever just no one knew.
What should I be looking for?
seriouslylotus
Contact:
Start with one that fits properly and is comfortable!
I find bell so uncomfortable!
I have an Aria shaped head...
andybond
Site Admin
Contact:
Comfort is a high priority, admittedly!
I guess its a case of go into a shop and ask to try on lots of lids?
I specifically want one with hans posts.
tlracer
Yep, the only way to get it right is forget specific brands, go to a reputable shop and try on as many as it takes to find the right one.
A good shop will understand and help guide you through the regs and ensure you get the best helmet for your needs.
series_one
Try them with closed eyes and no mirror, with the shop assistant helping you put them on blind and judge by fit feeling.
Im strongly Arai biased and if I dont do this I invariably know Im not judging fairly.
It’s all about head shape.
winthattt
Good advice on comfort, you have said HANS which I think is wise. It will get sweaty inside so look at how easily it comes apart to be disinfected. I use silver spray to keep the bacteria down. Though I have never tested it, get one with approvals. Snell 2015. FIA approval is also an option but may be over the top, though, just because it’s a track day you can still hit your head.
If you wear glasses, see if you can put them on with the helmet on your head, it is tricky!
Get a storage bag for it (and your HANS) and don’t let it get biffed in storage or in the boot of your car, I had to destroy one that got cracked in transit.
I have used Bell and Arai with no bother, I struggle getting cycle helmets to fit.
dris
If you're using harnesses HANS is a must.
I tried loads on but found I was between sizes with a few makes until I tried Bell.
Demon Tweeks usually have a good selection if you're in the area.
Fonzey
I was booked to go to the NEC for the Autosport show later in Jan for this very reason. Good opportunity to try lots on, usually.
Alas, it's been Covid-Postponed. Road trip to Demon Tweeks?!
andybond
Site Admin
Contact:
Fonzey wrote: Mon Dec 27, 2021 3:25 pm I was booked to go to the NEC for the Autosport show later in Jan for this very reason. Good opportunity to try lots on, usually.
That could work. Wrexham though isn’t it?
Fonzey
I never said it was a short road trip!
There's surely a closer alternative...
Create an account
Register
Sign in
