Static noise test
Topics relating to the Lotus Exige S2 (series 2)
andyzim
Can I have a bit of a poll here, what static test readings do you record on trackdays? And what is your exhaust setup?
Thanks
Fonzey
Varies from 92 to 98 on a full 2bular (8" backbox) w/ sports cat.
Depends which way wind is blowing, how cheap the meter is, how close the nearest wall is... etc etc, total farce!
seriouslylotus
Contact:
Always reads 105DB static at 5200 rpm (3Eleven with Standard Lotus system fitted)
661
92 static with a Chris Tullett large back box and de cat but it's the drive by that buggered me.
Supercharger whine trips the meters. Stupid really as the high pitched stuff doesn't travel to the houses, it's the low pitched exhaust stuff that's the environmental issue
Graeme
ade
661 wrote: Sun Feb 14, 2021 5:38 pm 92 static with a Chris Tullett large back box and de cat but it's the drive by that buggered me.
Have to agree, got black flagged at Donny due to SC whine going towards the microphones, they let me back on in the end as they agreed I could not have been setting them off going towards them, never went again on a quiet day as I realised I would never get away with it again.
The_Wizard
Had a similar issue with Roller Barrels on my Caterham R300 at Doni, ended up just shifting up early/part throttle under the start and finish bridge where the meter is hanging from, not the end of the world unless you are against the clock on a track day which you perhaps shouldn't be in all honesty. Apparently there is a meter at the back of the circuit but can't have been plugged in... :lol:
deggles
Donington is ridiculous, 98dB drive-by on the pit straight when you've got passenger jets taking off a few hundred feet directly above :lol: :roll:
