Thermostat Adaptor plate
Topics relating to the Lotus Exige S2 (series 2)
Fonzey
A while ago I fitted a mishimoto oil sandwich plate to help warm my oil up a bit quicker, and keep it warmer during road driving. It worked a treat, but the BSP oil fittings used by Lotus and the AN fittings that the rest of the world now uses was difficult to join together. I ended up with a series of adaptors which works, but are a little large and so clearance to the firewall is a bit tight.
A chap has been in touch about getting some made up, and he's looking to satisfy a minimum order. He's collecting names here if anyone is interested:https://forums.seloc.org/viewthread.php?tid=476414
MrP80
Fonzey wrote: Thu Feb 04, 2021 9:41 am A while ago I fitted a mishimoto oil sandwich plate to help warm my oil up a bit quicker, and keep it warmer during road driving. It worked a treat, but the BSP oil fittings used by Lotus and the AN fittings that the rest of the world now uses was difficult to join together. I ended up with a series of adaptors which works, but are a little large and so clearance to the firewall is a bit tight.
Cheers Kyle, name added :thumbup:
tlracer
What sizes are the AN and BSP threads?
Also what gender does the adapter need to be on either end?
Fonzey
It's 5/8 BSP male to M20 male if I remember right.
Mishimoto do M20 to XXX AN adaptors to suit most modern setups.
This is what I had cobbled together:
