Exige Cup 260 - Restoration and Updates
MrP80
Needed to adjust the diffuser as the original owner didn't get it fitted quite right, so it was pulling the rear panel out of place, I just had to adjust the side panels back and forward a few CM, not sure why Reverie didn't get these right as they aren't exactly variable but there you go:
It took quite a few goes and lots of adjusting, but it now fits properly. Not sure why it wasn't done on original fit, but easier to bodge than do properly. Bit of a polish on the diffuser to make it look a bit better
MrP80
Operation tidy up firmly underway…
No real mods to the engine bay since I decided to not fit the ProAlloy intercooler and cold air kit, keeping it OEM etc
So really it was a tart up as we'd already changed all the belts etc as part of the big service
Intercooler out to clean it and all that it blocks
Lots of scrubbing, dressing etc and it came up OK:
Then on to the removal of bits that I fitted and will never use in this car :(
Camera out first, before:
After
Seats back out again, so I can remove what was meant to be the extra sensor wiring:
SmartyCam recorder removed, it was down by drivers hip which seemed about the best place for anyone doing it. I also found that you can order just about any length of bullet cam cable, just order up a 50ohm cable with SMA connectors each end and it works great. You can make your owns for a few quid vs £80 from AiM and then you make them any length
Bulkhead and harness bar out to strip out the following (mainly as it cant be used without the AiM dash and that never got fired up outside the garage):
Data Hub, SmartyCAM, CAN Channel extender, plus all relevant extensions back to the sensors
Aux power feed, rear camera feeds remain as the next owner might want and I spent ages getting them all in and hidden away
Amazing how many nights were spent staring at the wiring trying to get it just right, all taken out in a few yours.
Next is to revert steering cowling and put back the OEM trim, as well as footcam (which works amazingly BTW, if a little dark due having less light with the rear window removed)
Fonzey
:cry:
HOON
:cry:
MrP80
Front half of the cabin now…
Shelf was trimmed with alcantara, easily removed as its tacked in with tape rather than glued but prefer the darker look, and stops stuff sliding about:
Trimmed the shelf ends as well (obviously kept untouched originals)
Spacer removed from steering wheel to get it all back to OEM, trimmed shroud and stereo control removed:
Will leave the alcantara wheel in as I much prefer the look over the original rubbish leather wheel, but I'll keep both in case
Foot cam removed, wiring and USB power has been left there but tucked out the way as it’s a useful feature to have.
Door cars removed, scrubbed then stain shielded - they has a bit of that sweet smell that was in the car and I wanted rid
Seats back in etc
Now everything back in and all good to go, quite a pointless exercise to install so many bits then remove, but that where we are And I suppose some regret that all the hard work on trimming wont be seen in all its glory. Excuse the less than great pics, it was very late:
What do we think rip the top half of the carpets back out and go with the half carpet half ali look of the S2? Personally I much prefer the look of all carpet, but don't know if that’s just cos I'm a weirdo
PaulT
Worst bit of this is obviously whatever's driven you to part with the car, nuff said, hope that's ok.
Second worst bit is I was loving this well-documented attention to detail. I'll miss this thread. :cry:
MrP80
PaulT wrote: Wed Jul 14, 2021 11:03 am Worst bit of this is obviously whatever's driven you to part with the car, nuff said, hope that's ok.
Alls fine, but I just need to change things around to get out of a rut - I'm not complaining people have far bigger worries than saying a plastic car doesn't fit into their lives so. Thank you though
Thread has been useful for me to keep on it, I know its been a bit too detailed but if someone gets something out of it or something is learnt then its all good, most folk are doing much more impressive things in their threads (or behind the scenes) and hats off to them. These cars are worked on in so many different ways from the epic build threads virtually from the group up, the track machines evolving over years to what is essentially a tart up, just shows the wide variety that can be had from a common platform - just by all the folk behind it
PaulT
MrP80 wrote: Wed Jul 14, 2021 1:06 pmThread has been useful for me to keep on it, I know its been a bit too detailed but if someone gets something out of it or something is learnt then its all good, most folk are doing much more impressive things in their threads (or behind the scenes) and hats off to them.
Don't do yourself down, there's a lot more work in cleaning cars and trimming interiors than folk (myself included) think. And taking the time to document it for t'internet. And that "nobody's gonna see this but.." approach. Hats off :clap:
MrP80
So no detailed steps just various bits and bobs of reattaching bits, cable tying, roof on etc
Just to get to the point that it is a finished car, apart from needing two stickers on the rear clam, maybe a polish on the rear clam to make it flawless, but otherwise shes done
Might even go out in her, but we'll see don't want to be too rash
MrP80
PaulT wrote: Thu Jul 15, 2021 9:19 am
Cheers, it now should be the best Cup260 in the country, pretty much everything on it new and or upgraded, suspension and paint all better than factory, bearings, dampers etc all replaced or fully rebuilt, all week points removed like additional of baffled sump, alloy rads, all mild steel brackets gone - apart from dropping the oil regularly there shouldn't be anything the next owner needs to do for 10 years, unless they buzz the engine or anything
Create an account
Register
Sign in
