BACON's honda elise/exige
Benja
Looks fantastic! Donny on Friday,..come on get it booked.
Really sorry I let you down on the lamp covers bud! I'm such a sieve brain sometimes. To be fair your shiny new ones look a lot better than my scratched old ones...
thommo
Looking good
Exige S1 No: 139
Good to go :clap:
R300
AMR V8 Vantage
BACON
Time for an update.
After a track day in2020 I decided to remove the rear clam just to have a poke about and see if everything was ok.
Last outting at Snetterton
I noticed some of the rubber fuel hoses were quite badly perished so decided to change them. One thing led to another and before long I had the engine out.
Actually I found a few more faults I couldn’t live with, including a cracked and bodged welded gearbox casing, tired engine mounts and so I decided to refresh the engine bay a bit.
Once the engine was out I stripped off the old sound and heat shield from the bulkhead. The induction kit i am using is an ITG carbon air box for the civic EP3, it is mounted to the left of the engine block with the intake nozzle pointing towards the side scoop. Except I couldn’t put a duct to it, because the fuel filter and regulator were mounted to a plate, in turn mounted to the roll bar stay. I decided to move these to the bulkhead and in an effort to neaten it up bought a new filter and regulator which has a return built in, doing away with a t piece.
New regulator filter and header tank with heat reflective foil applied to the bulkhead.
Another thing that bothered me was the steel coolant pipe that comes out the top of the thermostat then goes to the back of the engine, where in a civic it would have gone through the bulkhead to the heater. But on an Elise conversion it then turns through 180 degrees over the gearbox to t into the heater/header tank. I wanted a better solution so purchased the K-tuned V2 thermostat as pictured here.
The ports for the recirculation and heater are threaded to accept, in my case, -10 ORB fittings, which I have fitted with 5/8 hose barbs. The recirculation hose fitted fine and I’m hoping to simply run a hose across the bulkhead to T in to the header tank/heater.
When I head Dan at HPE was designing some new billet engine mounts I knew I had to replace mine for a set. I dropped off another k20 gearbox for him to clean and replace parts as he felt necessary. Recently I went to collect the refreshed box and the mounts.
The engine and gearbox went straight back in so I could finalise mocking up coolant pipe work and the laminova oil cooler.
This mock up shows roughly what I am trying to achieve, the small dia top pipe will have a silicone hose to the top of the thermostat and at the other end will T into the heater/header tank. The larger dia bottom pipe will fit to the thermostat and at the other end “dogleg” to fit to the rubber hose exiting the chassis rail.
That sort of brings me up to date, hopefully things can keep a bit of momentum now and have the car back together to start using it again next year.
Rob999
Ahhh the Gucci mounts 👌
#195
andybond
Site Admin
Contact:
A 5 year thread bump! impressive! :)
BACON
If anyone could tell me where those 5 years went I’d be grateful!! Thought I’d keep it all in one thread, for my own record really.
gonein60seconds
You can’t rush a good build thread 👍😂
S1 #501
thommo
Great update, albeit somewhat delayed. Keep us posted!
Exige S1 No: 139
BACON wrote: Sun Oct 10, 2021 10:44 pm If anyone could tell me where those 5 years went I’d be grateful!! Thought I’d keep it all in one thread, for my own record really.
I am literally living those five years right now.
Looking good, great effort.
R300
AMR V8 Vantage
Create an account
Register
Sign in
