Modifications to reduce head gasket failure risk
deggles
Stitches wrote: Thu Jul 21, 2022 2:53 pm Thanks for that. Will check the fan works as you kindly suggest. Is there an approximate temp range whereby the fan should kick in whilst stationary?
Hi, I think it should kick in around 104 as standard, or 92 if you have the 190 ECU. This is measured by the brown sensor at the ECU so might vary slightly from what you're seeing on the dash (blue sensor feeds the stack). :thumbup:
Stitches
Cheers! :thumbup:
Yes, so I believe it’s the standard cut-in temp (102-104 C) for the 177 bhp, and 92C cut-in for the 190 bhp ECU; cut-out will be a few degrees less.
If you’ve got an OBD reader plugged in that will give you the exact temperature that the ECU is seeing. If you’re going by the Stack temperature, it may show 3 or 4 degrees difference, and read high if there is any electrical load.
Stitches
That's really helpful, thank you
Create an account or sign in to join the discussion
You need to be a member in order to post a reply
Create an account
Not a member? register to join our community
Members can start their own topics & subscribe to topics
It’s free and only takes a minute
Register
Sign in
