My car is an early one without these fixings. I have had a look around this area and cannot see what the fixings would screw into unless they are just there for show?
Greenelise86 wrote: ↑Tue May 10, 2022 9:13 pm
the factory roof was supplied without the nutserts in, they were drilled and fitted once the clam was fitted
Thanks for the info. I can put my mind at rest now
Related to this thread, one of those two bolts circled in the first picture came off whilst I was on a track day at cadwell.
I think the inner fixing is rattling around inside the car somewhere as getting a knocking noise sometimes - any idea how I might be able to locate it? Not sure how to get behind it…
without taking everything apart your unlikely to locate it. best bed would be to squirt a little expanding foam or silicone into the are you think it is. this will stop it rattling, then you can fit a new fastener. ive done this a few times on the front roof fixings
