Aircon...more Con than Air!!!
<Archived> Even supercars have their flaws..
Guest
Re: Aircon...more Con than Air!!!
Post by Guest »
erm...I don't mind mine...at least, mine is sort of working...... [image]http://www.smilies-world.de/Smilies/Smi ... ndsofa.gif[/image] Bruno [image]http://www.smilies-world.de/Smilies/Smi ... lsuper.gif[/image]
jfk
Post by jfk »
got to add....
mines an 06 exige and the aircons fine !
fook .... it'll probably break down tomorrow now .... !!!
2006 exige S 37 K miles
Mikespeed
Post by Mikespeed »
i can confirm that my 05 exige air-con does not make any difference to the incoming air temp.
Has anybody come up with a fix or had it regased ?
tim_marra
Been thanked: 1 time
Post by tim_marra »
[quote=Mikespeed]i can confirm that my 05 exige air-con does not make any difference to the incoming air temp.
Has anybody come up with a fix or had it regased ? [/quote]
A common fault on the early 'yota cars is that the pipes corrode just inside the sill aft of the front wheel arch. It can be fixed with an upgraded (rubber coated i think) replacement from Lotus. Expect to pay circa �600 at a dealer.
Have some tracer dye put though first to confirm.
blackstone
Post by blackstone »
How easy is it to remove air con system?
I didn't think it was fantastic over summer, made a slight difference to cabin temp but not enough to justify carrying the extra weight or burning the extra fuel.
Mr Pesky
Post by Mr Pesky »
Tal
There's summat up with your system - it should be very effective.
Why are you worrying about weight savings, when you don't even track it, or know what it/you can do as it is? I won't mention tyres........ ;)
ade
Been thanked: 8 times
Post by ade »
S2 air con shoud work quite well, on hot days I use it on track as well ;)
pete757
Post by pete757 »
[quote=ade]S2 air con shoud work quite well, on hot days I use it on track as well ;) [/quote]
Any excuse for not enough power!!! :grin:
ade
Post by ade »
Absolutely, more power means I can leave the air con on on track ;)
Mr Pesky
Post by Mr Pesky »
[quote=ade]Absolutely, more power means I can leave the air con on on track ;)[/quote]
And at least you have a car to take on track! :D
Locked
