Mrs Thommo thinks it might be crocheted (That’s pronounced “crochay”, I believe.) rather than macrame.
No crack smoking going on here . . .
Exige Cup 260 - Restoration and Updates
I presumed it was the old diffuser was past its best! Being honest mine is the only Cup260 I've seen in the flesh!
Are you up north/midlands then? Would be good to yours as no two seem alike on final spec!
So bank holiday weekend didn't go exactly to plan, it was meant to be 4 days full of car stuff and some nice food. Reality was I was stuck working so it was back to midnight sessions again, really need to sort the new career thing…
Time to get rid of this crappy wheel whilst the rest of the interior goes back in:
Usual power down so it doesn’t blow up in my face, and airbag was taken out, just thought I would show it as people seem to not post much on removing the airbag
Remove this green tab to release the connector
4 bolts to be removed
And wheel off
Then simply swap the old wheel, for the new wheel and spacer with longer bolts, installation is a bit tighter as the cable is about its limit, you could maybe run a 40mm spacer if you wanted to push it, but cables will be at their max on installation
New wheel, spacer and steering shroud done:
And wheel off
I presume it was something along the lines of “how do we save 50p on one of the 4 main contact points for the driver?”
