At present #138 is having some TLC and having some upgrades that it should have had before leaving the factory. Below is a breakdown of the work that will be carried out by Jon to get #138 back to its best.
Full Suspension Refresh:
Strip all suspension components, shot blast/powder coat, and reassemble with new bushes/track rod ends/ball joints/hub packs/toe links. Rustproof non-aluminium parts.
New/Replacement Parts:
Aluminium Radiator, AC Condensor, Stainless Steel Tow Post, TRD Airbox & Filter, Hand Brake Cable (A120J0039F), Brake Pads, Engine Mount Inserts, Central Locking Module (A132M0118F).
Major Service:
Filters: Engine Oil Filter & Fuel Filter
Oil & Fluids: Engine Oil, Gearbox Oil (Red Line MT-90), Brake Fluid
Spark Plugs
Drive/Supercharger Belt (B128E6008F).
Dampers:
Ohlins 2-way Adjustable Dampers (factory option)
LSD:
Quaife ATB Differential (opted for this since I have it on another car, and due to its longevity and lifetime warranty).
Suspension stripdown began a few weeks ago - no pitting, but looks rather manky:
Wishbones and ARB (not pictured) are back after being shot blasted and powder coated - no pitting so good smooth finish:
During assembly (only some photographs have been posted):
#138 is now mobile, with the old Bilsteins installed, until we get the new Ohlins, which caused a bit of a delay as they had to be shipped from Germany, and then re-valved and have the correct spring rates set by Mick Gardner Racing. However, these are expected to be delivered this week.
Front clam will be coming off next week to have a look in there and address any issues that may be lurking underneath, such as having a new aluminium radiator, AC condenser, and stainless steel tow post.
That is it for update #1. Looks like I will get to drive #138 before the summer is out...can't wait!
