S2 NA + Mods
ade
I have had similar clutch problems with a lack of disengagement especially when hot, it was found to be the centre plate getting stuck on the input shaft of the gearbox, this meant when you depressed the clutch it would only pull the pressure plate away from the centre plate, but the centre plate would drag on the flywheel as it wasn't free to move. I hope that makes sense? John (ex JSR) used a special grease on the input shaft, expensive fix having to take the box out to add some lubrication on the shaft! No pun intended......
matt447
ade wrote: Fri Jul 15, 2022 9:33 am I have had similar clutch problems with a lack of disengagement especially when hot, it was found to be the centre plate getting stuck on the input shaft of the gearbox, this meant when you depressed the clutch it would only pull the pressure plate away from the centre plate, but the centre plate would drag on the flywheel as it wasn't free to move. I hope that makes sense? John (ex JSR) used a special grease on the input shaft, expensive fix having to take the box out to add some lubrication on the shaft! No pun intended......
That does make sense, and sounds very much like what I'm finding... I think I'll have to look at a new release bearing at the same time as I can't honestly live with this noise much longer, lol! I'm half tempted by a slightly less aggressive clutch too? I have the ACT HD SS clutch and with the Fidanza flywheel it seems to shake the whole car as you slide into first, lol!
Fonzey
What was your thoughts on the gains with the lightweight flywheel? I didn't really notice mine to be honest, it was thrown in with many other parts - but when I did a back to back session with another Exige S on the standard flywheel I really didn't notice.
Even with all else left equal, I think a LWFW will add a little bit of noise to a gearbox as you're losing some 'damping' in the whole drivetrain which the inertia grants you from a pig iron original.
I think if I did it all again, I'd just get the original skimmed and reuse that.
matt447
Fonzey wrote: Fri Jul 15, 2022 11:14 am What was your thoughts on the gains with the lightweight flywheel? I didn't really notice mine to be honest, it was thrown in with many other parts - but when I did a back to back session with another Exige S on the standard flywheel I really didn't notice.
My friend had his low mileage 111R in at Track-Group for the KAAZ gearbox after he tried mine - and he asked whether he should do the Fidanza flywheel at the same time... I said the same thing to him, that it was possibly the least noticeable change I've made, and it has brought a few downsides along with it. In my head, I thought it would spin up a fair bit quicker and rev nicely... but it just didn't seem to be any different, lol! It just seems to be less tractable now at low speeds, but with no noticeable benefit, so I wouldn't entertain buying one again if I had my time again. After telling him that, he just went with the gearbox and an Exedy clutch, and now he has a really nice setup for a NA 2ZZ...
ade
I would not bother with a lightweight flywheel again just for the sake of it, I don't think there is enough benefit, I would fit one if mine was knackered but not just because I'm in there.
Fonzey
Seems we're all in agreement. I guess the 2ZZ OE flywheel is already pretty light(??) it's not like these clomping great V8's that move from a 40kg dual mass jobbie down to a 4kg billet biscuit :lol:
JDS
Fonzey wrote: Fri Jul 15, 2022 2:49 pm Seems we're all in agreement. I guess the 2ZZ OE flywheel is already pretty light(??) it's not like these clomping great V8's that move from a 40kg dual mass jobbie down to a 4kg billet biscuit :lol:
It's all relative though. Next time you come over, I will drop a standard flywheel on your head/foot/other. Are there lighter options? Yes there are. Take out the gearbox just to change to a lighter flywheel, maybe not. Change while the clutch is being changed, yes.
On the other hand, I can sell you all some really, really heavy wheels!! And take those worthless 240R rims off your hands :thumbup:
Fonzey
Believe me I know what a flywheel to the foot feels like :lolno:
I also know what happens when you frisbee one into the garage loft and it comes into contact with the electrics from the house that are dropping down into the consumer unit. Story for another day :mrgreen:
ade
Fonzey wrote: Fri Jul 15, 2022 8:27 pm Believe me I know what a flywheel to the foot feels like :lolno:
That would have been an expensive mistake.......
matt447
I liked the RLS wing ends, but they don't seem to be available nowadays, so I designed a replacement wing end for the factory early S2 rear wing, then had it cut from Carbon Fibre. Really happy with the results!
Create an account
Register
Sign in
