2006 Exige S
andybond
Reactions:
Has thanked: 37 times
Been thanked: 30 times
Contact:
Re: 2006 Exige S
Post by andybond »
Excellent write up. This is all invaluable information and also a good read!
thommo
Reactions:
Has thanked: 3 times
Been thanked: 20 times
Re: 2006 Exige S
Post by thommo »
Very methodical. I’d be useless faced with the same tasks. I’d put a nut and bolt “somewhere safe” and lose them
Fonzey
Reactions:
Has thanked: 28 times
Been thanked: 15 times
Re: 2006 Exige S
Post by Fonzey »
It's certainly daunting, particularly when dismantling it all in the first place because the end goal just seems to keep getting further and further away.
Little things help though, labelling wiring and sorting/storing fittings in something like this:
The diagrams on deroure are also invaluable, honestly wouldn't know where to start without those - plus it gives me part numbers of stuff I need to replace when I cock it up!
Some progress/milestones achieved this weekend so far, will get my next update put together later tonight with any luck.
Fonzey
Reactions:
Re: 2006 Exige S
Post by Fonzey »
More updates, on babysitting duty tonight so good opportunity to sort through photos and get myself caught up. It's been a hectic few days, sorting out jobs on the Lotus in the odd 30min slots so progress a bit scatter gun but some pretty nice milestones have been ticked off and suddenly everything is coming together.
Still no progress on the AC pipe, but that can wait till last now as it can be the last thing I do before the clam goes back on really.
With the radiator shroud off the car, I could build up my stack of new radiators and plan out the modifications to the shroud before fitting it all together and dropping it back on the car as a complete unit.
The Pro Alloy kit comes with some brackets which are specifically intended for coexisting an AC condenser with a radiator and a charge cooler pre-rad. The only instructions that came say "these are unique on each side, so get them the right way around", with no guidance as to what "the right way round" actually is :lolno:
The AC condenser also came with some brackets which were riveted on. It looked like these needed removing so that my charge cooler bracket could replace it, but I wasn't 100%. Luckily where instructions/documentation is lacking - support from Pro Alloy is fantastic, answers to emails within an hour or so confirmed that the AC condenser rivets needed drilling out and the brackets binning.
Once this hurdle was cleared, it was just a case of stacking the rads and figuring out how it all went together. Seemed pretty straight forward but no obvious clues still as to what the "right way" was. I figured I had a 50:50 chance so just cracked on.
The new twin pull fan setup came on a laser cut bracket which bolted to the top:
Next up I had to chop the connectors off the old fans and solder them onto the new setup. The polarity here will influence the direction of the fans, I did a test run with a battery and joining blue to blue and black to black blows the fans in the correct direction, but apparently the polarity and colour coding on the "car side" can be a bit random... some people report putting it all back together and finding their fans blowing wrong, so need to make a note to test this before clam goes on!!
The next step was to figure out where new holes needed cutting into the radiator shroud to get the extra hoses through. Made up a quick template using the original rad hose and AC hose outlets as a reference:
...which led to:
Unfortunately it was not destined to remain this tidy. I later went onto find that fitting the rads back into the shroud required a fair bit of angle and pivoting so the holes ended up enlarged by quite a bit. It would have been quicker and cleaner to just cut out a massive void to take all outlets, it's not like this shroud needs any real strength.
Fitting back into the shroud made me realise what was finally meant about putting the brackets on "the right way round" and guess what, I'd got it wrong. The summary is that the back of the radiator needed some bolt holes clear for fitting to the shroud, and they were occupied by a stud on the "wrong" bracket, so had to dismantle it all and swap them round.
The OEM rad is covered in foam strips to stop air from escaping round the sides of the radiator. I ripped those off and copied onto the new rads, and used some extra sponge to fills some gaps.
It's pretty airtight round the radiators now, better than the stock arrangement - every little helps but I'm not entirely convinced my adhesive will survive the heat/airflow stresses so it might all just fall off and rattle around behind my grill... we'll see.
Here we have a bit of a milestone, rads and shroud fitted back to the car!
I spent a bit of time reminding myself where all the wiring had to route to supply the driving lights, horn, light clusters, etc. The oil coolers aren't back on yet as they could do with a bit of tarting up.
Easily the most daunting part of the charge cooler install is running the coolant hoses down the sill. A few posts ago I posted the following diagram which had to options for routing:
I decided to go green because:
a- It's the most direct route, requires less hose and "gentler" bends.
b- It's the only route I could find first hand experience/advice on... so I know for sure it's possible.
The first thing to do was hack a hole through the side impact foam at the back. Luckily removing the sidepod provides great access:
You can see the foam in question, forming the "floor" of the sidepod.
I started hacking away at the front edge of it with an array of screwdrivers and chisels, and it didn't actually take too long at all.
The main issue is I didn't manage to recover hardly any of the dislodged foam... so it's down in the sill somewhere, but I imagine it'll work it's way out eventually through the "red route" of the diagram.... or stay there forever, who cares.
Once I proved to myself that two lengths of hose could make their way down into the sill (very tight), I started thinking about the strategy for pushing/pulling the hose through. I could either go from the front of the car and try to fish the hoses up through the hole in the foam, or push the hoses through from the rear and figure out how I get them out of the front later. I went for the latter.
Using some wire-fishing-pole things that electricians use to feed cables behind walls etc, I poked some string through to the front of the car, tied it to a length of hose and then got pushing/pulling. As it turned out, the string was pretty much useless and I did pretty much all of it by pushing. Eventually it popped through into the access hole in the cockpit. (no picture of this, but here's the end of my fishing rod for reference)
The second hose was a bit harder, as obviously the channel was now more congested but it really didn't take long. The biggest issue with this job was injuries to my hands... the inside of the sill is like a meat grinder with unfinished edges, bits of rivet, clips and potentially maybe even a rodent of some kind just taking chunks out of me any time I went in there.
The wifi endoscope I got at Christmas has really earned its place during this work, really impressed with it and wish I'd bought one sooner!
With both hoses 'available' in the car interior, I felt quite relieved - as this was pretty much the hard part done! The next/final part will be to drill holes in the front of the sill, fit the grommets and then try and poke the hoses up through them. The positioning of the holes needs to be well thought out, as I've got oil cooler lines and AC pipes back there and I need to both avoid damaging them, and find a route that I can use.
Couple of other bits of tidying up involved the brackets holding on the driving lamps, they really rusted away on my old Elise so required a bit more of a refurb but these were sound, so I gave them a quick coat of hammerite spray and will XCP them up once dry:
I noticed one of my lenses has a stone chip too, so might replace that before the clam goes on.
Next steps are:
- Get the hoses out of the sill and connected to the pre-rad
- Reconnect main rad once new jubilee's arrive
- Top header tank up and bleed out all the air. After disconnecting the HVAC, rad and a bunch of hoses I think I've lost more coolant that I first realised so might take some time
Once that's done, I can turn my attention to the rear of the car. Intercooler needs to come off (minutes of effort) and the chargecooler fitting with header tank. Before it goes on I'm going to lift my cam cover and check for wear on my intake cam lobes. This wear was a bit of a thing on some 2ZZ engines, no confirmed root cause but I later found (after selling it) that my old Elise suffered quite badly from this and it was the same 2006 vintage.
Oh, and finally between all this we bought a new daily:
Focus ST-3 Estate, baby is getting heavier and the car seat was getting more and more awkward in the back of the 3dr Civic. It's got a fantastic spec, gadgets everywhere (but the Ford SYNC satnav is awful). Nice to have a bit of torque back in the daily fleet too, after the Type R and Clio182 it was becoming a bit exhausting :? 182 is now also up for sale, hint hint.
andybond
Reactions:
Contact:
Re: 2006 Exige S
Post by andybond »
Great write up. Enjoyed reading about your pro alloy exploits!
thommo
Reactions:
Re: 2006 Exige S
Post by thommo »
More bedtime reading. Thanks. Like the new motor👍
Fonzey
Reactions:
Re: 2006 Exige S
Post by Fonzey »
Glad you're enjoying gents, I enjoy writing - a job like this feels hectic (and painful) when doing it but I know I'll miss the constant source of tinkering once the car is done, so reading these threads back that I write lets me re-live it from time to time.
If somebody else enjoys reading, then that's just a bonus :lol: On a serious note though, I honestly don't think there's a single detailed write-up of an Exige CC install out there, a couple of decent VX220 ones but there are some key differences. Hopefully people can actually find this useful and inject a bit of bravery to do the work themselves.
ade
Reactions:
Been thanked: 10 times
Re: 2006 Exige S
Post by ade »
Seeing the trouble you went through I'm so glad proalloy fitted mine, well it was their test mule and it is hardly a surprise they had it for a while!
Fonzey
Reactions:
Re: 2006 Exige S
Post by Fonzey »
ade wrote:
Sun Jan 12, 2020 10:06 pm
I read through a lot of your early chargecooler posts when scraping for info, I certainly wouldn't want to be doing the R&D on this kit in the first instance! In fairness though, the kit does seem well put together and other than being time consuming it's really not been too difficult yet. Most of the time I've spent on the car so far has also been HVAC related, so can't really blame the CC for that entirely.
If my posts deter somebody else from having a go at this install then that would be a shame, it's well worth taking on if you've got a basic tool set and some patience/time. I'm rather enjoying it!
Fonzey
Reactions:
Re: 2006 Exige S
Post by Fonzey »
Oh a little nugget that I often hear/read speculation about. How much weight does a CC setup add?
I've now got all of my "OEM" components off the car so I can work out the weight penalty delta. Assuming that the 5l of coolant spec from Pro Alloy is correct, then the total weight gain will be 13.55kg. I might shave a little bit off once the hoses are trimmed down to their final length.
9.85kg of that is from the hoses and the coolant, the rad stack itself adds around 2kg and the chargecooler/header tank/pump adds about 1kg between them.
In raw bhp/tonne terms that means that on a 260bhp baseline that I need to gain just 5 usable BHP to retain the same power:weight ratio. If Pro Alloy are close with their 20bhp claims, then obviously this is a fairly strong net gain (even though I'm doing this for tracktime longevity and not headline figures). Obviously power:weight is only part of the equation, so I will be aiming to lose that 13.55kg from elsewhere on the car in the longer term anyway.
I've got the pig-iron standard wheels, so there's an "easy" if not cheap way to knock 10-11kg right away. New battery and then we're already there without anything intrusive.
