2006 Exige S
andybond
Site Admin
Reactions:
Contact:
Brilliant update. Really useful info. The aircon man interests me as well. I wonder how many aircon pipes he could make ...
Fonzey
Reactions:
Yep hopefully he comes good, I'll be sure to feedback once we have a conclusion. If nothing else, I think he can help get me in touch with the right people. I've rung up about 30 hydraulics places (who knew North Yorkshire had such a demand for hydraulic engineering shops) and nobody will touch AC. I've found one mail-order place, but their indicative pricing would make me just want to sign up for the backorder queue with Lotus...
I checked his FB page out and he's done a couple of pipe replacements recently on campervans which tend to have pipes running under the car. He's converted from the ally pipes to rubber/barrier pipes for better longevity so that's also an option for me.
https://www.facebook.com/CoolDrive-Auto ... 893277790/
Fonzey
Reactions:
Quick update on the AC - Stuart (link above) has been for a look today and he's got a plan. The main complication with the damaged pipe is that it contains a pressure relief/blow off valve to protect the system in the event of a fault. That stops us from just running a replacement soft hose and means that making up a replacement hard line is a little more complicated.
The plan I think we'll go with is running flexi at each end with a small hard section containing the (existing) pressure relief valve in the middle. My Chargecooler hoses have also congested the area more than I first appreciated, so running the original hard pipe may be a challenge in itself anyway!
I need to write/format my next big update as I managed to make some good progress over the weekend in other areas.
ETA: Not that it should matter, but the fella is clearly a petrolhead... and he also has an old Elan tucked up somewhere waiting for a few restoration jobs! It came off the road in 2011 for a minor brake refurb and it just never got finished. Hopefully I've bullied him enough to put a few garage hours in and get it roadworthy this summer!
andybond
Site Admin
Reactions:
Contact:
Sounds like progress!
Fonzey
Reactions:
I managed to get a few bits done over the weekend, but slowing down now as I know I can't get the car properly buttoned up until the AC is sorted and I'm actually running out of jobs to get done!
With the hoses trimmed and clipped up at the front of the car I now needed to map out my routing at the rear. The shorter of the two sill hoses would be connecting directly to the charge cooler unit closest to the boot, so that was a simple route over the roll-over bar (to stop it catching the aux belt/pulleys) the longer hose would be connecting to the outlet of the pump.
To help mock everything up I started refitting the engine mounting hardware.
You might notice a funnel in the coolant header tank in the background, over a few days I had been very slowly "gravity bleeding" the system to try and get a head start on the proper bleeding process.
I also fitted the header tank, this was bolted to a supporting bracket of the roll-over bar.
With the charge cooler mounted to the top of the engine, and header tank fitted I could start mocking up my hoses. Obviously being very keen to not over-trim them... The sequence of components is:
header tank bottom port -> pump inlet -> pump outlet -> long hose to front -> pre-rad -> not quite so long hose to rear -> front port of CC -> rear port of CC -> header tank top port.
The hoses are a rather tight fit, so a nice bath before installation helped things along nicely.
The pump is a very dinky unit and is designed to be suspended by the plumbing alone, but I found a convenient place to mount mine under the top lip of the bulkhead trim. The bulkhead is carpeted so should dampen any vibrations from the pump and the highly engineered cable-tie support will stop it from bouncing around off of the inlet manifold.
With everything trimmed down, the setup started to look half decent:
I'm still not sure whether I like the CC in the brushed ally look that it comes in, or whether I'd prefer it in satin black to make it a little more subtle. I think I'll take the year to make my mind up and either paint it or leave it next winter. I think it looks a bit too blingy with the hatch raised, but when lowered it stands out just enough to let you know it means business...
The funnel part from the roof scoop will be remaining in place as I believe it's bonded in, and it's a bit of a one-way decision to remove it. I'd always like the option of returning to the air:air system in future.
With jobs running out I did a quick oil/filter change ready for the process of bleeding both coolant systems.
The plan was to leave the CC pump disconnected whilst I concentrated on getting the main circuit bled, with the heater matrix and rad being completely dry I expected this to be a bit of a pain in the arse. After a couple of sessions of running the car up to temperature I seem to have a hot heater circuit and heat in both end-tanks of the main radiator... so I don't think I'm far off now. The fans kick in as expected, when expected and they're blowing air in the right direction which is a bonus!
Next up is the CC circuit. I want to run as little anti-freeze in this as possible just to maximise the efficiency of it so I've been testing it along the way with a tester. I'm aiming for a basic -7deg C of protection and the rest will be distilled water, and a bottle of (snake oil?) water wetter for good measure. It's looking like 2L anti-freeze, 2.5L distilled water and 0.5L of water wetter being my final mix.
I filled up the header tank and allowed a bit of it to drain through via gravity. With no bleed screws or other openings, this obviously wasn't going to work well for long. Whilst letting it dribble through, I got on with the pump wiring.
The kit from Pro Alloy includes a little piggyback link which is attached to an engine bay fuse. The fuse specified by Pro Alloy is a 10a fuse in the inboard most fusebox which according to the Exige manual is for the Injectors and Ignition coils.
The harness has an inline fuse holder so the circuit is still protected, and on the other end is pinned up for the bosch pump with a final tail to be grounded somewhere.
I got everything wired up and used a ground on the ECU mounting plate, all in the same area and very close to the pump which kept everything nice and tidy. With the ignition flicked to ACC, the pump whirred away so at least something was working. I peeked into the header tank and saw no evidence of coolant moving around at all.
I left it going for *some time* and still no evidence of any coolant being pushed around. I was beginning to fear a kink or blockage somewhere so I took the top hose off of the header tank and blew an airline through the system backwards. Sure enough coolant came splashing though the other end after a few seconds - so the system seemed to be clean.
I wondered if the polarity was wrong on the pump, so took the wiring back out for a closer look and found a few questionable bits.
When the 2-core cable was stripped it looks like the sheathing on the wiring was also cut, exposing the cores. Also the rubber seals for the plug are in backwards, and not in properly at all. This made me wonder about the quality of the crimping and whether I could potentially have a dodgy connection. I can hear the pump going, so it clearly works - but the flow (when held in open air) is very very weak.
Pro Alloy support throughout this install has been amazing, so first thing on Monday morning they got back to me with some pointers for further bleeding the system as the pump is just not designed to push air, and hence it probably feels very weak. They also agree the wiring isn't great so they're sending me out another plug. Happy days.
I'm going to try and force a bit more water into the system by lowering the front end of the car to the floor and filling the system backwards with a funnel. Hopefully that combined with rewiring the plug will get the water moving around nicely.
Whilst tidying up some of the interior trim I dismantled, I came across a casualty of the install. The back-end of the door switch (that controls the alarm/interior light) had been knocked off by my hose wrangling. The back of the switch is broken, but luckily is readily available and costs <£10 - so got one of those on the way, then the interior can go back together.
I'm thinking of setting a date for getting my geo sorted (remember all those posts back when I fitted new suspension? Feels like a lifetime ago...) to encourage me to get a move on.
ade
Reactions:
I'd still suggest adding in a second pump, it turned what was a low volume of water going through the system, to what I considered a good flow.
Also provides some redundancy. Oh and the pumps should not be run without water, it is design to use the water as it's lubricant :)
ade
Reactions:
Nice install by the way, over time I modified mine to use 90 degree bends in place of trying to bend the very strong pipes proalloy supplies, it just takes some of the pressure of the fittings.
Fonzey
Reactions:
ade wrote:
Wed Jan 22, 2020 9:58 am
Cheers Ade, yeah I only ran the pump in thin air for a few seconds just to check the electrics. Once I plumbed it into the car, it wasn't run until the header tank was filled - and the pump was only a few inches down stream from the coolant in there so I'm fairly sure the innards would have been submerged and lubricated.
I'm not ruling out the second pump, just wanted to get the install up and running as-is and then take some benchmarks. I particularly like the idea of having the redundancy of the second pump, but as I think @andybond mentioned in another thread, more flow doesn't always = better heat transfer, there's a sweetspot. (I just don't know where that is :D )
ade wrote:
Wed Jan 22, 2020 10:00 am
Quite early in the install I decided there was a lot of potential for 90deg connectors making this cleaner and easier. As it is I've managed to keep all of my bends quite "swoopy" but if I was to do this again in hindsight I'd probably stick some 90deg connectors inside the sill right near the front to get the hoses out into the open a bit cleaner, and I could probably shave a foot of hosing off the install if I installed a 90deg from the header tank facing down to meet a dangling pump and the feed pipe for the sill. All improvements I plan to make over time.
Sort of on that note, have you found a reliable way to drain the system of coolant before chopping and changing the pipework? I'm concerned that my sill run is the low point of the system and is likely to collect water, I'd like to avoid having loose coolant sloshing around my sills if I need to make an adjustment. I'm thinking of setting up an airline attachment so I can just blow it all out when needed.
ade
Reactions:
I left the pipe work alone in the sills, I used the 90s to ease the connections to the rad mainly, this also allowed a better line from the rad to the bulkhead again easing some strain on the connections, just didn't want a fracture of the inlet or outlet of the pre rad as it is just such a ball ache to get to.
Final thing I did, well John at JSR did, was to use ralays to run the pumps from the ignition circuit with a direct fused feed from the battery, I just didn't like adding the pumps to that location in the electrics, thought it was better to run then directly and leave alone the car electrics as much as possible.
He did all this when he fitted the gearbox cooler, ended up with a relay and fuse box in the boot for all the extra electrics just next to the battery.
Fonzey
Reactions:
Yes the pre-rad connectors are IMO the biggest chance of a hose kinking when hot due to the tight routing there, they would indeed be a good spot for 90deg connectors. I may do that before the clam goes on, as it may actually tidy up that area in time for the AC man to come back and fit (yet another) pipe in there.
I'm also thinking I could pull a few inches of slack out of the sills, chop the hoses on the outside, fit a 90deg connector to each and then pop the new right-angle back through the hole and poke the grommet back in afterwards. That would also take out a high kink risk.
ETA: Did you get plastic/nylon connectors or did you find some metal ones?
The Relay/Direct connection is the 'traditional' way to wire this setup up. I'm good friends with a VXTurbo owner who chargecooled his a couple of years ago and he went down that route. If my pump still isn't pushing any fluid through after I have another stab at the electrics then I think I'll go down this path and just sort it the "old fashioned" way. I'm really no auto-electrician so I don't fully understand the concepts and differences between the Pro-Alloy "piggyback" route and a relay/battery route though. (I know how each one works, I just don't know the pros/cons of each compared to each other).
