johnfishcurtis
Those seats look great :thumbup:
Plus the crotch harness hole makes hoovering and trying to find coins/McDonald chips/sweets/fluff a lot easier!
andybond
Site Admin
Contact:
johnfishcurtis wrote: Sun Jan 24, 2021 7:00 pm Those seats look great :thumbup:
Never thought of the hoover aspect.
andybond
Site Admin
Contact:
I have now fitted both seats. The second seat took two hours after dropping the seat bolts 18000 times. Bloody frustrating.
To add to the frustration one of the captive bolts that holds a corner of the roof panel is no longer captive.
Ah , balls.
andybond
Site Admin
Contact:
See post : viewtopic.php?f=12&t=21476&p=244959#p244959
I have ordered Silverhook BIGK1 Big Boy Glass Fibre Resin Repair Kit and Isopon P40 Fibre Glass BodyFiller ordered. Be here Monday / Tuesday.
I am not making up the name of the resin kit ...
How hard can it be to fix the bobbin?
andybond
Site Admin
Contact:
A big thanks to @lotuslee and @Fonzey for bouncing ideas off them here. I have zero GRP experience ...
I had to take the head off the clunk bolt , and I needed to remove the metal bracket to let me create an inspection panel to see whats what.
I then cut out an inspection panel so I could see if the captive nut was spinning, or something else
It is the captive bolt that's spinning. I have some really small plyers that I can pinch the nut with to stop it spinning and the headless bolt now stops spinning.
I am awaiting some isopon40 to be delivered and I am going to place this inside the inspection chamber towards the bottom to get the nut to stop spinning again ( in theory ) Ill let that cure and give the headless bolt a twist to see if it breaks the isopol40 bond that's just been created.
Assuming it doesn't I am torn here as
1) I have found a nut that fits on the end of the headless bolt and will clamp the metal bracket that is used to hold the roof down. Its a non OE fix, but it works, and works well. Even with the captive nut twisting!
2) I could cut a groove in the headless bolt and try and unscrew the headless bolt out, but doing so could jeopardise 1) as the nut might not go back on any longer. If not I would have to goto . . .
3) Cut out the whole piece and wreck my headlining and reset in the captive nut.
Choices , choices ...
andybond
Site Admin
Contact:
I couldnt let it go.
Happy days - that is the old clunk bolt with head cut off out.
Will tap the thread out as it appears to be a bit of a mess tomorrow and await the goo to hold the nut in place.
andybond
Site Admin
Contact:
This afternoon straight after work I have managed to ;
Tap with my 1.25*M8 the thread. It took some doing and blunted my tap at the end. My son was pinching the metal part that was visible whilst tapping and after a short while the tap turned freely. Success.
I can now get a m8 straight in and out with minimal fuss. This will yet to be seen when its on the car!
I then mixed the isopon40 up in a small quantity and tried to use the spatula to wedge it in. No dice. Too small. Used my fingers and pressed loads into the void to try and hold it all together. I have put a m8 in place to try and create the void for the bolt to reside in. I am hoping it doesnt set and stick to the bolt.
Pic :
Fonzey
Maybe a bit late but I'd have lubed the crap out of that bolt just to reduce the chance of anything bonding to it.
Any update? This is looking like a good fix, if you can get that bolt out :lol:
andybond
Site Admin
Contact:
Fonzey wrote: Tue Feb 09, 2021 10:41 am Maybe a bit late but I'd have lubed the crap out of that bolt just to reduce the chance of anything bonding to it.
I took the bolt out when it was tacky, fortunately!
I need a shorter bolt, as this one just about touches the top skin, but Ill get it sorted :)
andybond
Site Admin
Contact:
Fixed! Feels secure.
