Fonzey
matt447 wrote: Thu May 13, 2021 10:43 am
Fonzey wrote: Thu May 13, 2021 9:04 am I've just bought myself a set of AD08RS for any future 'monsoon days' that we may get. I'm guilty of never actually trying a 'road' tyre on an Elise platformed car before... both of mine have been on ZZR's pretty much exclusively so I may use the AD08's on at least one dry day somewhere just to see how the car feels, to see if the threshold of grip comes down enough that I can actually have some fun!
I've got AD08RS as my wet-weather tyres, used them once at a dry Donington and it turns out they're really good - for about 4 or 5 laps, then they got very 'squirmy'. You've got more power, and an LSD, so you may be able to play with them a bit as the grip threshold lowers. I found them an exceedingly good tyre when all's said and done - but the R888R is a damn site grippier and consistent in the dry, but in the wet they're obviously much more frisky
I think that account probably adds up with what Andy has experienced. Where the AD08's start "going off" on a session, something like a ZZR or R888 just hold their ground so a generally going to be more consistent over a session. Looking forward to trying my AD08's really, first time running a different tyre, always like an opportunity to experiment.
andybond
Site Admin
Contact:
Exactly.
You have to really drop the pressures. Testing at blyton told me ;
24f/26r COLD
3 laps resulted in
30f/32r HOT
I dropped that to 24r/22f HOT and it was fine all day doing 7-12 laps per stint.
andybond
Site Admin
Contact:
IACV gasket acquired. I’ll see if I can find an hour or so over the weekend to clean the IACV.
I must look into getting the MFRU sorted as well
andybond
Site Admin
Contact:
Everything is clean and working well.
I might have trapped the IACV wire at some point but hopefully you can all gloss over that and concede that its now working as it should
Result.
ade
andybond wrote: Thu Jun 10, 2021 4:22 pm Everything is clean and working well.
Result.
Nothing to see here, move right along ;)
matt447
ade wrote: Fri Jun 11, 2021 7:23 am
Result.
Hahaha! :lolno:
andybond
Site Admin
Contact:
Another trip back to Blyton with my good friends over at https://diamond-performance.co.uk/. I dont tire of this track as its quite technical and a good benchmarking track.
Today I had full confidence that my car would start after a trip to see SeriouslyLotus the day prior and John worked his magic on my electrics which have been causing me a headache for a while now.
I also changed the front damper to taking nan to physio spec ( C ) Fonzey where I am now running 10 clicks from hard both on front and rear. Once the fronts were upto temp I was amazed how much better it was turning in. More playing of settings ahoy I feel.
Some images of the day :
andybond
Site Admin
Contact:
Just got back from a very enjoyable evening trackday sesh.
one 30min session and 3 lots of 20 minute sessions.
TBH in todays heat it was plenty! I tweaked my setting on the suspension slightly and found myself with a better setup than session 1. I had a mild spin ( 90 deg off forward ) and then adjusted the settings. It was like night and day. The mid corner bounce was gone and when I was trying to exit too fast all I got was slip. Keep the toe in and powerslid out.
I felt like Clarkson every time I did it. Even did a thumbs up for a photographer on a hairpin. It appears you dont need >500hp to drift when you want have have to have the letter C and 63 ..
This setup will try and kill me at Blyton I feel.
For my records :
Blyton F10 R10
Donington F10 R14
andybond
Site Admin
Contact:
A couple of pictures whilst I wait for the pros to upload.
A hardboiled egg wearing glasses :
Two warm tyres.
MrP80
Looks like a cracking evening from all I've heard from you and the other guys! Glad everyone managed to get in a properly good summer evening session!
