GT3 kitted exige s
ade
Reactions:
My old car has 600 850 springs and still road the bumps very well indeed
SeanB
Reactions:
Rob999 wrote:Pilbeam if you have the monies.
And can deal with their shocking customer service
Neil A
Reactions:
evo_ufo wrote:Do Cornering Force still fit rear ARBs?
I heard back from cornering force today , they still do the roll bars but they come in at £850 :o .
That is for a 3 position rear bar with mounting brackets and adjustable drop links and bladed front roll bar with drop links , expensive but when you look at the pilbeam bar for over £500 you do get a lot for the money.
Because my car already has the valving and spring rates designed to work with these i'm tempted to bite the bullet and order them up, rather than trying a cheaper bar that may not work as a package.
SeanB
Reactions:
Sounds like a plan!
Neil A
Reactions:
Ordered :)
Looks to be a well thought out bit of kit with a lot of testing behind it , couple of weeks lead time so will get pics up when it arrives.
Neil A
Reactions:
I had heard about these engines breathing heavy so thought i would be better to fit catch cans if I'm going to track it , went with Sector11 quick cans.
Look to be well thought out as far as separation but not overly impressed with the fit, I'm not sure if they are meant for NA cars as one of the hoses rubs on the intercooler mount bracket so will have to mod that a little.
Also don't like the fact the drain plugs are just pushed into rubber grommets, would of rather them threaded in especially since they are close to the hot exhaust if they were to ever fall out.
Also fitted a removable wheel to make getting in and out a little easier.
Anti roll bars should be here this week.
winthattt
Reactions:
The Radium cans are nice but I had to add a spacer under the fitting bolts to stop them fouling any pipework. Luckily the spacers on my son's micro scooter wheels are perfect. The Radium's need to be unscrewed to empty them which is a bit of a fiddle but I have found they can go a few track days between emptying sessions, in fact one never gets anything much in it.
ade
Reactions:
I had the proalloy ones, still not perfect as mine didn't have a sight glass, but that might have been sorted now
661
Reactions:
I have the Sector ones and they seem to do the job.
Graeme
Neil A
Reactions:
Gained another project / garage mate for the lotus , god knows what I'm going to do with it but 182's are just a fun little car to drive.
