S1- S2K
osmond1
Reactions:
So I've been thinking about this for a while....
Stripped the car down...
And get some S2k wishbones and bearing packs...
New driveshafts...
The uprights are with Ollie at Phoenix having 5 mm machines off the fronts and some brackets made for the AP 4 pots.
I have new AP 308 discs and a couple of sets of team dynamics on the way too. Wishbones are currently at the powder coaters, not being done black ;)
Once it's all bolted back together it's off to TTS fir a significant power increase ;)
Marc.
stevegreen
Reactions:
Sounds interesting - what's the main reason for the change?
Who are TTS?
osmond1
Reactions:
Ability to run the bigger and easier to change bearing packs being the biggest benefit.
TTS is where my engineer friend Darren works, they are Honda and Rotrex specialists ;)
osmond1
Reactions:
Clam off...
Clean up the chassis..
lautll421
Reactions:
looks good......
stevegreen
Reactions:
definitely does - did you use anything special to clean the chassis?
osmond1
Reactions:
I used some degreaser, and some autosol with very fine wet and dry paper. Will spray some acf-50 on it all too before reassembly.
SeanB
Reactions:
what is acf50?
OrangeD
Reactions:
stevegreen
Reactions:
search for it on seloc - it went through a craze there as the must have accessory - even persuaded me!
