Back at it again.
ade
Reactions:
Is that a sport cat or a silenced decat?
evo_ufo
Reactions:
[quote=ade]Is that a sport cat or a silenced decat?[/quote]
Silenced decat.
evo_ufo
Reactions:
Car has been running superbly. Having to be pretty careful with it. Not used to this 3rd and 4th gear wheel spin :)
It has been back at Hangar 111 this week for a spanner check and an oil change. While it was there had the corner weights checked. Really pleased with the results when you consider the car now has a rear cage, charge cooler, and the dry sump gubbins.
That is with 80kg in the drivers seat and 35 to 40 litres of fuel. By my reconning that still puts it under 900kg. About 370 brake/ton. Not near Frank but enough for me for now. :)
Reactions:
Spa then?
R300
evo_ufo
Reactions:
Afraid not. Planning on more days closer to home this year until I start to forget how much this has all cost :)
Reactions:
Donny on the 27th April then :)
R300
evo_ufo
Reactions:
Very temping. Got Snetterton next weekend, then Anglesey. Will see how I'm doing on the noise front before signing up.
jfk
Reactions:
Oil cooler and jubu equipped in the gearbox should hopefully keep it safe.
Wheelspin in 3rd ? Ooerr ...are you still on the open diff Will?
Looking very potent and should scare a few Honda S/C S1,s ;)
Burstner/Ducato Motorhome
Benja
Reactions:
[quote=jfk]should scare a few Honda S/C S1,s ;) [/quote]
Will was pretty good at that even before he started fooking about with it....
jfk
Reactions:
Agreed ... The quickest ,most accurate pax ride I've ever had !!
