Thanks for input chaps, I will get back on it in the next few days and take a look at those suggestions.
The headlights earth you suggested @winthattt - I've removed head light connectors and sprayed contact cleaner but the earth for the headlights, where do I find this?!
Headlights and indicators glowing on
I’m not sure where the front headlamp ground is. In the two pictures you can see where the main front earth point is, I expect it ends up there. You can also see the clamp wiring and the connector which must have the ground. It’s the earth to the chassis that must be good. I would not expect clean inside a bulb holder to help but it was worth a try.
