Starter Motor S1
ortope
In the meanwhile I repaired the original starter motor with the spare part ordered from Wood Auto.
job done
# S1 016
For the benefit of anyone else who may experience the same problem in the future, was it the pinion/lever part that needed replacing? Or was the cause something else?
ortope
The primary problem was that the gear was incorrectly shrinked on the flywheel (!) and consequently
the starter-cog was consumed abnormally (work performed by a Swiss "specialist" by the way).
After having replaced the clutch and the flywheel during the complete overhaul, sometimes the starter didn' t engage on the gear...
Problem solved with the new part delivered by Wood Auto (many thanks to "tlracer" for the tip).
:thumbup:
# S1 016
ortope
Remounted the repaired starter motor today.
Everything works nicely.
Problem solved.
:thumbup:
# S1 016
Excellent!
Starter motors in general seem to suffer from minor but problematic faults - a case in point is the small Denso units. These are generally very reliable but the solenoid contacts wear and they stop working. Fix takes 10 minutes plus a few readily-available and inexpensive parts.
