I started with the bonnet as it was already off the car.
Taping up was relatively easy other than right up to the edges and under the lip to cover all of the grilles. The grilles are in really good condition and so don't need any spraying or refurb.
All taped and ready to sand. There are a few stone chips that will need filler but most will be covered by primer.
I also taped the under side and will ask for this side to have a spray of base coat (no primer) to hide the respray.
I sanded with 320grit to get the key needed for the primer to grab hold.
I also need to key the doors and sills but it is much easier than sanding right back.
