VHPD Engine inspection
Topics relating to the series 1 Exige
winthattt
Reactions:
Been thanked: 3 times
Re: VHPD Engine inspection
Post by winthattt »
We have had the builders in and they just lifted it onto the stand for me, I have trouble lifting the cam cover. For Thommo, you will be interested in my bikes when they slip into shot.
Paul Donahue Reynolds 653 Steel, Campag, restored by Mercian. My first proper race bike. Paul made frames for team Linda McCartney and Brite in the 90s.
Cotic BeFe Reynolds Steel hardtail.
Principia RSL, Campag Record. The original frame, Swiss alloy tubes, custom made n Denmark, result, bankrupt. Same bikes were used in the Tour de France for the big climbs, usually painted to look like other top brands.
Omega Alchemy Titainium Record. 15 years old, ridden it across Europe. Still like new, that’s titainium. Allegedly UK made but I suspect made in Russia.
Planet X track bike. Full carbon, just had to buy two new tyres, £150 plus £100 fitting!
Boardman team cyclocross bike. Great I. The mud and gravel that passes for roads this time of year.
trackrod
Reactions:
Has thanked: 2 times
Been thanked: 2 times
Post by trackrod »
That looks like an interesting thread, Keith and I will follow it closely. If I remember right Roger from Sabre Heads metioned somewhere (Seloc?) that the numbers on the head were stamped by Janspeed. They indicate the volume per cylinder and the amount that the head was skimmed.
thommo
Reactions:
Has thanked: 3 times
Been thanked: 20 times
Post by thommo »
Good collection of bikes there, I look forward to seeing them. I have five complete cycles. The sixth, my Vitus restoration, came to a halt in the summer but I’ll get going on it again soon.
C8LGY
Reactions:
Post by C8LGY »
Following with interest! I don’t have a spare VHPD lying about, might need to keep an eye out and join the club! :lol:
winthattt
Reactions:
Post by winthattt »
Turned the engine upside down today and removed the sump pan. To my untrained eye it all looks very good. I used my trusty magnet and could not find any ferrous parts. There is no significant sludge or grit either. Next I will take the cam cover off and check the valve clearances. The vhpd has mechanical tappets which have to be shimmed up for tolerance. If they look good the signs are very promising. Step after that is to remove the oil rail so I can check the big end bearings and the crank float.
One area where I have failed is trying to remove the pulley wheel from the crank. It needs to be removed to remove all of the plastic cam belt covering. I jammed the flywheel side with my trusty wrecker’s spike and tried to undo the bolt on the pulley. I now have a bent wrecker’s spike. Next step will be to fit a scrap flywheel so I can really jam the crankshaft and then have another go. I’m hoping a Gavin at Unit 4 will have one which I can “borrow” when he services my S1. Any tips, I’m scared to use my impact driver, should I be?
I’ll post some pictures when I can take them. I only had 30mins today and that’s as far as I got.
Keith
winthattt
Reactions:
Post by winthattt »
Pictures from the sump removal and a bit of inspection.
Nothing nasty in the sump. My magnet picked up no bits and it just felt like oil between the fingers.
Underside of the engine. I thought, incorrectly, that I could remove the oil ladder (the but that looks like a ladder) and get at the big end shells. As I can now see the bolts that hold the head on go all the way though and hold the ladder in place. That means I cannot fully inspect the bottom end until the head is off. I was aware that the K-series has this unusually construction. The ladder looks nicely made but not the most rigid of structures. Depending on what I do I may get a new Chinese one which is supposed to be much better, all depends on the state of the engine.
This is the pesky bolt that will not come undone. I'm sure when I can jam the crank solid I'll have a better chance.
No Vernier pullies fitted. Can anyone tell me if they are the 190 upgrades? I can read a part number.
Picture looking into the engine. You can see the black stretch bolts from the head (I think it is them) and just see the big ends.
winthattt
Reactions:
Post by winthattt »
Next job is the take the cam cover off and check the solid lifters to see if the clearances are OK. If they are, it's going to be "off with it’s head".
C8LGY
Reactions:
Post by C8LGY »
I would have thought that an impact driver would be the best thing to loosen that crank pulley, think they are normally torqued to the same level as hub nuts which are notorious for being a challenge!
Interested to see how easy the shim clearances are to check - the bulk of my experience is is with push rod engines but fancy having a go at checking my own shims.
tlracer
Reactions:
Has thanked: 1 time
Post by tlracer »
1) Yes, the long through-bolts sandwich the whole assembly together. There's been a massive amount written over the years about these and the construction method, its effect on liners, etc.
2) The 190 pulleys are the standard units, with an additional slot machined into the inlet pulley. As such it has the same numbers visible on it. Removing the bolt & washer will uncover the 'new' slot, if it's there. 190 upgrade usually had other parts fitted too, eg. 82 degree thermostat, which might be an easier-to-see clue.
winthattt
Reactions:
Post by winthattt »
That makes sense. I’ll take the bolt out and have a look. No thermostat on the engine.
